Problems implementing a new facet [message #166849] |
Fri, 14 April 2006 16:28  |
I've been the investigating the possibility of using project facets for
our project. Based on the limited documentation that I can find on the
subject of project facets, I am under the assumption that they are used
for adding certain pieces of functionality to a WTP based project (i.e.
Dynamic Web Project). We have a certain type of project that "extends" the
Dynamic Web Project. Hence, we are looking to use a facet to represent the
functionality extension of the Dynamic Web Project.
I believe that I have set up the facet extensions and project wizard
correctly but am running into a snag. It seems that there is a check made
during the course of running the project wizard that checks to make sure
that the facets defined for the project are all defined as "runnable" on
the selected runtime (i.e. Tomcat 5.0). If the check fails (as in my case)
things blow up.
So, my questions are;
1) If this is true, how does a developer that does not create a new
runtime of his own, add a facet to an existing runtime (i.e. Tomcat 5.0)?
2) What is the advantage of using a facet as opposed to just using a
standalone nature to add the extra functionality?
Thanks.
- Don
Re: Problems implementing a new facet [message #166876 is a reply to message #166860] |
Sat, 15 April 2006 12:05  |
Originally posted by: bdmetz.us.ibm.com.spam
Hi Don,
I thought I'd point you at some presentations which might help from
EclipseCon:
http://eclipsezilla.eclipsecon.org/php/attachment.php?bugid= 241
I can tell you to answer your #2 question, one major facet feature that I
think is a big improvement over natures is a uniform UI control over
installing/removing facets from projects and the ability to group and
prerequisite facets based on other facets being present. You can also sort
the order in which they are installed on a project and do some neat
install/uninstall/upgrade handlers.
"Don Sedota" <sedota@us.ibm.com> wrote in message
news:56669258965bd5d9d2f6de413aa02939$1@www.eclipse.org...
> No, I didn't post to answer my own question, but did stumble upon the
> answer to question #1 shortly after posting. Using the
> org.eclipse.wst.common.project.facet.core.runtimes extension point, you
> can allow a facet to run on a particular runtime. For example to allow
> facet "myfacet" to run on Tomcat 5.0, the following extension will do;
> <extension point="org.eclipse.wst.common.project.facet.core.runtimes">
> <supported>
> <runtime-component id="org.eclipse.jst.server.tomcat" version="5.0"/>
> <facet id="myfacet" version="1.0"/>
> </supported>
> </extension>
> - Don
FUDForum. Page generated in 0.06394 seconds
