Home » Language IDEs » ServerTools (WTP) » Help interfacing with Websphere Rapid Deploy WRDExec
Help interfacing with Websphere Rapid Deploy WRDExec [message #166841] Fri, 14 April 2006 14:39 Go to next message
I'm working on modifying the WTP Websphere plugin to publish an EAR file
using the Websphere Rapid Deploy tool (for version 6.0) instead of wsadmin
install/uninstall. Specifically, I'm trying to automate the startup of the
WRD application, which is essentially a headless Eclipse app which listens
to a specific project directory and auto-installs any EARs placed there.
The problem I'm having is with the WRDExec application. It is not really
an API, but more of a command-line utility you run and keep open until
you are done with, and then type 'q' to quit. I've tried the Ant exec task
on the batch file that runs WRD, but the problem is that when WRDExec goes
to look for something on STDIN, it finds nothing and immediately shuts
down. I've also tried the Ant java task, but that simply either hangs
forever if I don't spawn it, or immediately shuts down if I do.
There is virtually no documentation online about WRD and its interfaces.
Does anyone know if there is an API that I can use to manage WRD better?
Thanks in advance,
Jonathan
Re: Help interfacing with Websphere Rapid Deploy WRDExec [message #166868 is a reply to message #166841] Fri, 14 April 2006 17:16 Go to previous messageGo to next message
I was able to solve my problem partially by discovering that WRDExec has a
-batch option which starts the workbench, runs the build script, then
stops the workbench. This is good enough, even though it won't pick up an
undeploy, which isn't a big deal.
Jonathan
Re: Help interfacing with Websphere Rapid Deploy WRDExec [message #170305 is a reply to message #166868] Mon, 29 May 2006 16:01 Go to previous message
Originally posted by: aknuth1.gmx.de
Jonathan,
sounds like an interesting way to manage the publishing for websphere.
Just a few questions on that:
- Did you just replace the Ant file that shiped with WTP for Websphere ?
---> by using the <autoAppInstall ...> - task
( http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. jst.j2ee.doc.user/topics/tantautoappinstall.html)?
- Does that bring a performance gain on publishing in comparison to
wsadmin install/uninstall?
- Do you use "freeform" or "autoappinstall" in your tests
regards,
Andreas
Previous Topic:Problem with META-INF/services
Next Topic:Problem using We App Libraries container standalone
Current Time: Sat Jul 26 03:53:48 EDT 2025
Powered by FUDForum. Page generated in 0.05521 seconds
