Home » Eclipse Projects » Eclipse Platform » Tree from Resources
Tree from Resources [message #166793] Sat, 06 December 2003 13:38 Go to next message
Originally posted by: dcorbin.machturtle.com
Is there a handy-dandy class that will, given a collection of resources, act
as a Tree content provider for them?
David
Re: Tree from Resources [message #167104 is a reply to message #166793] Mon, 08 December 2003 06:49 Go to previous messageGo to next message
i don't know if this is what you're looking for, but check out the common
navigator:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-ui-home/docs.html
cam
"David Corbin" <dcorbin@machturtle.com> wrote in message
news:bqt7hs$eht$1@eclipse.org...
act
> Thanks
> David
Re: Tree from Resources [message #167685 is a reply to message #167104] Mon, 08 December 2003 18:36 Go to previous messageGo to next message
I took a quick look, but don't think it does. The closest thing I've found
so far is a FileFolderSelectionDialog, but that's internal.
Perhaps if the ContentProvider, sorter, etc. from this were available as
part of the API, that would go 90% of the way.
David
> navigator:
> cam
> act
>> Thanks
>> David
Re: Tree from Resources [message #168792 is a reply to message #166793] Wed, 10 December 2003 13:10 Go to previous message
Originally posted by: John_Arthorne.oti.com_
By "resources" do you mean IResource objects? In that case
WorkbenchContentProvider will work for you. This content provider uses
the IAdaptable mechanism to defer the work to the object in the tree.
See also WorkbenchLabelProvider and IWorkbenchAdapter.
> Thanks
> David
Previous Topic:Need help Creating an ImageDescriptor
Next Topic:Dynamic Action Contribution
Current Time: Thu Nov 06 02:41:24 EST 2025
Powered by FUDForum. Page generated in 0.24841 seconds
