Home » Eclipse Projects » Sirius » Edge centering problem(sirius 2.0)
Edge centering problem [message #1665077] Wed, 11 March 2015 00:43 Go to next message
Hello all,
As release note of Sirius 2.0, You can specify that an edge end will always be centered. And there are The Centered Source Mappings and the Centered Target Mappings within the edge style description advanced properties tab. But after I upgrade to sirius 2.0, I find no option like that in advanced properties tab.
What should I do to get Edge Centering?
Thanks in advance.
Re: Edge centering problem [message #1665618 is a reply to message #1665077] Wed, 11 March 2015 06:06 Go to previous messageGo to next message
This option is not located on the Edge Mapping but on its style
sub-element. Go to the Advanced tab and you have the new parameter "Ends
Centering" with the radio button options: None / Both / Source / Target.
Steve
Le 11/03/2015 05:43, khanh tran a écrit :
> Hello all,
> Thanks in advance.
Steve Monnier - Obeo
Need professional services for Sirius?
Re: Edge centering problem [message #1667342 is a reply to message #1665618] Wed, 11 March 2015 22:57 Go to previous messageGo to next message
Hi Steve,
Thank you very much, but in the advance tab of edge style, I just have Size Computation Expression and Folding Style. I don't know why.
Re: Edge centering problem [message #1667931 is a reply to message #1667342] Thu, 12 March 2015 04:53 Go to previous messageGo to next message
Are you sure that the update to Sirius 2.0 worked? It might have failed
for some reason. This feature has definitely been contributed in Sirius
2.0 (see https://bugs.eclipse.org/bugs/show_bug.cgi?id=437528). Note
that this feature is not available for a sequence diagram, as the edge
source/target location has an ordering meaning.
Steve
Le 12/03/2015 03:57, khanh tran a écrit :
> Hi Steve,
Re: Edge centering problem [message #1670449 is a reply to message #1667931] Fri, 13 March 2015 03:41 Go to previous messageGo to next message
Hi Steve,
Currently I have a *.odesign file with sirius 1.0. Then I upgrade to sirius 2.0 by upgrade from update site.
Some new features in sirius 2.0 like Snap to Shape or Outline (automatically moves the displayed zone of the diagram) are work fine.
Is there anything else I need to migrate *.odesign file from 1.0 to 2.0?
Thanks in advance.
Re: Edge centering problem [message #1671113 is a reply to message #1670449] Fri, 13 March 2015 09:15 Go to previous messageGo to next message
I have to try to update from 1.0 to 2.0, because I do not see why this
feature would not be available for you. Can you tell me what exact
version you upgraded to? 2.0.4?
You just need to open you VSM (*.odesign), the migration is automatic.
Steve
Le 13/03/2015 08:41, khanh tran a écrit :
> Hi Steve,
> Thanks in advance.
Re: Edge centering problem [message #1677988 is a reply to message #1671113] Sun, 15 March 2015 23:34 Go to previous messageGo to next message
Hi Steve,
The version that I upgraded is 2.0.0. Please see attachment files for more detail.
Thank you very much.
  • Attachment: plugins.PNG
    (Size: 62.99KB, Downloaded 110 times)
  • Attachment: Edge.PNG
    (Size: 19.83KB, Downloaded 127 times)
  • Attachment: EdgeStyle.PNG
    (Size: 16.23KB, Downloaded 111 times)
Re: Edge centering problem [message #1682244 is a reply to message #1677988] Tue, 17 March 2015 13:02 Go to previous message
How did you updated to Sirius 2.0? I have just updated a Sirius 1.0.0 to
Sirius 2.0 using the market place and it works fine. My VSM model now
display the "Ends Centering" option in the advanced tab of an Edge Mapping.
Steve
Le 16/03/2015 04:34, khanh tran a écrit :
> Hi Steve,
Previous Topic:Sirius post-condition expression?
Next Topic:Petri-Net Editor Edge Constraints
Current Time: Sun Jul 27 16:16:25 EDT 2025
Powered by FUDForum. Page generated in 0.05054 seconds
