Home » Archived » BIRT » Report with SQL or other
Report with SQL or other [message #165871] Wed, 31 May 2006 02:53 Go to next message
Originally posted by: s.claes.gfdi.be
I'd like create report with an SQL String, for example paste the SQL
String to the report and that's all.
Is it possible ? If you have an example, it's wonderful.
Thanks for your help.
Re: Report with SQL or other [message #166716 is a reply to message #165871] Thu, 01 June 2006 12:32 Go to previous message
I am not certain I understand what you want.
At the minimum you will need to create a Data Source and a Data Set (Where
you paste the SQL)
You can then drag the table to report canvas.
Jason
""St
Previous Topic:Ajaxing the Scripted Datasource
Next Topic:about rptdocument question
Current Time: Mon Nov 10 04:30:41 EST 2025
Powered by FUDForum. Page generated in 0.03718 seconds
