Working example of Xtext and XBase [message #1666113] |
Wed, 11 March 2015 10:50  |
Hello
I am looking for a working example that uses Xtext and Xbase, to have some Java-like expressions in my DSLs.
There are some examples out there from the examples of the Book on GitHub. But, they do not compile with Xtext 2.8.0.v201503090534. I managed to compile them via Xtext 2.7.3, but when I execute the language, I get the following exception.
What are rather easy ways of having some Java-like languages with Xtext? I have seen there is a SmallJava example in book, but there is no code generation for it...
192506 [Worker-11] ERROR org.eclipse.xtext.builder.clustering.ClusteringBuilderState - Error loading resource from: platform:/resource/Test2/e1.xentities
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.net.MalformedURLException: unknown protocol: java
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:229)
at org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getResource(SynchronizedXtextResourceSet.java:24)
at org.eclipse.xtext.xbase.typesystem.references.LightweightTypeReference.internalFindTopLevelType(LightweightTypeReference.java:645)
at org.eclipse.xtext.xbase.typesystem.references.ParameterizedTypeReference.getSuperTypes(ParameterizedTypeReference.java:483)
at org.eclipse.xtext.xbase.typesystem.references.LightweightTypeReference.getSuperTypes(LightweightTypeReference.java:370)
at org.eclipse.xtext.xbase.typesystem.override.AbstractResolvedOperation.getOverriddenAndImplementedMethodCandidates(AbstractResolvedOperation.java:138)
at org.eclipse.xtext.xbase.typesystem.override.AbstractResolvedOperation.getOverriddenAndImplementedMethods(AbstractResolvedOperation.java:52)
at org.eclipse.xtext.xbase.typesystem.override.OverrideHelper.getReturnTypeOfOverriddenOperation(OverrideHelper.java:114)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.getReturnTypeOfOverriddenOperation(LogicalContainerAwareReentrantTypeResolver.java:1000)
at org.eclipse.xtext.xbase.typesystem.internal.OperationBodyComputationState.createNoTypeResult(OperationBodyComputationState.java:62)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractRootTypeComputationState.computeTypes(AbstractRootTypeComputationState.java:31)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:787)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:689)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeMemberTypes(LogicalContainerAwareReentrantTypeResolver.java:857)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:846)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:683)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:675)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:152)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:132)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultBatchTypeResolver$1.reentrantResolve(DefaultBatchTypeResolver.java:96)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.resolveTypes(CachingBatchTypeResolver.java:79)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:56)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:36)
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:127)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.doResolveTypes(CachingBatchTypeResolver.java:52)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractBatchTypeResolver.resolveTypes(AbstractBatchTypeResolver.java:55)
at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:64)
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.resolveLazyCrossReferences(BatchLinkableResource.java:151)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:513)
at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:219)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.update(AbstractBuilderState.java:112)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:187)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:167)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:95)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:734)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:299)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:302)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:358)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:381)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.net.MalformedURLException: unknown protocol: java
at java.net.URL.<init>(Unknown Source)
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:199)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.xtext.resource.XtextResourceSet$1.createInputStream(XtextResourceSet.java:262)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 47 more
192510 [Worker-11] ERROR org.eclipse.xtext.builder.clustering.CopiedResourceDescription - java.lang.IllegalStateException: getReferenceDescriptions platform:/resource/Test2/e1.xentities
at org.eclipse.xtext.builder.clustering.CopiedResourceDescription.getReferenceDescriptions(CopiedResourceDescription.java:79)
at org.eclipse.xtext.builder.builderState.BuilderStateUtil.copyReferenceDescriptions(BuilderStateUtil.java:59)
at org.eclipse.xtext.builder.builderState.BuilderStateUtil.create(BuilderStateUtil.java:34)
at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:256)
192511 [Worker-11] ERROR org.eclipse.xtext.builder.clustering.CopiedResourceDescription - java.lang.IllegalStateException: getImportedNames platform:/resource/Test2/e1.xentities
at org.eclipse.xtext.builder.clustering.CopiedResourceDescription.getImportedNames(CopiedResourceDescription.java:71)
at org.eclipse.xtext.builder.builderState.BuilderStateUtil.copyImportedNames(BuilderStateUtil.java:40)
at org.eclipse.xtext.builder.builderState.BuilderStateUtil.create(BuilderStateUtil.java:35)
222885 [Worker-11] ERROR org.eclipse.xtext.builder.clustering.ClusteringBuilderState - Error loading resource from: platform:/resource/Test2/e1.xentities
... 47 more
222887 [Worker-11] ERROR org.eclipse.xtext.builder.clustering.CopiedResourceDescription - java.lang.IllegalStateException: getReferenceDescriptions platform:/resource/Test2/e1.xentities
222888 [Worker-11] ERROR org.eclipse.xtext.builder.clustering.CopiedResourceDescription - java.lang.IllegalStateException: getImportedNames platform:/resource/Test2/e1.xentities
Re: Working example of Xtext and XBase [message #1667949 is a reply to message #1666113] |
Thu, 12 March 2015 05:02  |
On 11/03/2015 15:50, Som 2015 wrote:
> Hello
I still have to update the examples of the book to Xtext 2.8.0, I will
do that in the next few days. The Xbase example won't compile with
Xtext 2.8.0 because Xtext artifacts have to be regenerated, by running
the mwe2 workflow.
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
FUDForum. Page generated in 0.04363 seconds
