Deploy DSL [message #1665523] |
Wed, 11 March 2015 05:14  |
Good morning,
I would like to deploy my DSL as a project. I explain myself:
I would like that my DSL appears as a new project (File > New Project...). Moreover, when a model of my DSL is created, I would like to have the viewpoints (diagrams, tables) associated to it automaticaly.
Is it possible to deploy my DSL in Eclipse?
Thank you,
Adrien.
Re: Deploy DSL [message #1665643 is a reply to message #1665523] |
Wed, 11 March 2015 06:24  |
If you want to contribute a new wizard you will need to use the Eclipse
UI extension point "org.eclipse.ui.newWizards".
As you want to initialize a modeling project with a model conforms to
your DSL, I think the easiest is that you look how is contributed the
"new modeling project" wizard. Look for
org.eclipse.sirius.ui.tools.internal.wizards.ModelingProjectWizard. I
guess that your wizard should extend this one and add a step where you
create your own model of your DSL and activate the dedicated Viewpoint
that you specified in your DSL.
By the way, if needed, you can go further and check the "Initialization"
parameter on a "representation description" in your VSM to automatically
create a Diagram/Table/Tree on activation of your viewpoint. You can
also check the "Show on startup" parameter so these Diagram/Table/Tree
will automatically open. This way your enduser could work directly after
the wizard process without investigating where/how to create a
representation.
Steve
Le 11/03/2015 10:14, Adrien Lefevre a écrit :
> Good morning,
> Thank you,
> Adrien.
Steve Monnier - Obeo
Need professional services for Sirius?
FUDForum. Page generated in 0.12725 seconds
