| Eclipse 3.2 installation problem on OS X Tiger [message #166510] |
Sun, 20 August 2006 03:39  |
Originally posted by: untz786.yahoo.com
Hello there,
I downloaded the Eclipse 3.2 tarball for OS X Tiger... Also installed the
JDK 1.5.0_4 and SWT_compatibility for Eclipse 3.2.
Too my surprise the only thing that was inside the tarball was a plug-ins
directory, I moved this directory over my current eclipse's plug-in
directory and launched eclipse.
The splash screen did specify that I was using Eclipse 3.2. However, right
after the splash screen, the app crashed and had me refer to a log under
Configuration.
Here's what the log stated:
===== Display starts at offset 64700 within file of length 195772. ====
===== Use File->Reload (Cmd-R) to display more. ====
scanDoctypeDecl(XMLDocumentScannerImpl.java:595)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDispatcher.dispatch(XMLDocumentScannerImpl.java:860 )
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 368)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at
org.eclipse.update.core.model.DefaultSiteParser.parse(Defaul tSiteParser.java:126)
at
org.eclipse.update.core.model.SiteModelFactory.parseSite(Sit eModelFactory.java:78)
at
org.eclipse.update.internal.core.SiteURLFactory.createSite(S iteURLFactory.java:78)
at
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:330)
at
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:322)
at
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:294)
at
org.eclipse.update.internal.core.InternalSiteManager.attempt CreateSite(InternalSiteManager.java:218)
at
org.eclipse.update.internal.core.InternalSiteManager.getSite (InternalSiteManager.java:159)
at org.eclipse.update.core.SiteManager.getSite(SiteManager.java :78)
at
org.eclipse.update.search.UpdateSearchRequest.searchOneSite( UpdateSearchRequest.java:345)
at
org.eclipse.update.search.UpdateSearchRequest.performSearch( UpdateSearchRequest.java:253)
at org.eclipse.update.ui.UpdateJob.runUpdates(UpdateJob.java:20 0)
at org.eclipse.update.ui.UpdateJob.run(UpdateJob.java:163)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.441
!MESSAGE Error parsing site stream.
!STACK 0
org.xml.sax.SAXParseException: White spaces are required between publicId
and systemId.
at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(ErrorHandlerWrapper.java:236)
at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. fatalError(ErrorHandlerWrapper.java:215)
at
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(XMLErrorReporter.java:386)
at
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(XMLErrorReporter.java:316)
at
com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFat alError(XMLScanner.java:1438)
at
com.sun.org.apache.xerces.internal.impl.XMLScanner.scanExter nalID(XMLScanner.java:1024)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.scanDoctypeDecl(XMLDocumentScannerImpl.java:595)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.442
!STACK 0
and systemId.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:32:05.444
!MESSAGE Unable to access "http://update.eclipse.org/updates/3.0".
!STACK 1
org.eclipse.core.runtime.CoreException: org.xml.sax.SAXException:
FWK005 parse may not be called while parsing.
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1283)
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.445
!STACK 0
org.xml.sax.SAXException: FWK005 parse may not be called while parsing.
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.447
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:32:05.448
!MESSAGE Unable to access "http://update.eclipse.org/updates/3.1".
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.449
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.450
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:32:05.451
!STACK 1
org.eclipse.core.runtime.CoreException: org.xml.sax.SAXParseException:
White spaces are required between publicId and systemId.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.453
!STACK 0
and systemId.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.455
!STACK 0
and systemId.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:32:05.456
"http://download.eclipse.org/tools/uml2/updates/".
!STACK 1
org.eclipse.core.runtime.CoreException: org.xml.sax.SAXException: The
XML stream is not a valid default "site.xml" file. The root tag is not
site.
at
org.eclipse.update.core.model.DefaultSiteParser.handleInitia lState(DefaultSiteParser.java:365)
at
org.eclipse.update.core.model.DefaultSiteParser.startElement (DefaultSiteParser.java:170)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:533)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(XMLNSDocumentScannerImpl.java:330)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl$NSContentDispatcher.scanRootElementHook(XMLNSDocumentSc annerImpl.java:779)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1794)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.458
!STACK 0
org.xml.sax.SAXException: The XML stream is not a valid default "site.xml"
file. The root tag is not site.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.460
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:32:05.461
!STACK 1
site.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.463
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.465
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.update.core 4 42 2006-08-19 22:40:47.360
!MESSAGE Network connection problems encountered during search.
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:40:47.361
!MESSAGE Unable to access "http://scala.epfl.ch/downloads/eclipse".
!STACK 1
site.
at
at
at
at
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. startElement(XMLDTDValidator.java:798)
at
com.sun.org.apache.xerces.internal.impl.XML11NSDocumentScann erImpl.scanStartElement(XML11NSDocumentScannerImpl.java:354)
at
com.sun.org.apache.xerces.internal.impl.XML11NSDocumentScann erImpl$NS11ContentDispatcher.scanRootElementHook(XML11NSDocu mentScannerImpl.java:855)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.update.internal.ui.views.FindUpdatesAction$Track edUpdateJob.run(FindUpdatesAction.java:93)
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:40:47.363
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:40:47.364
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Aug 19 23:04:26 Raven configd: SecKeychainFindGenericPassword err=
-25308 ( =0xffff9d24, secErrStr=User interaction is not allowed. )
(current= Phantom's Den)
!SESSION 2006-08-19 23:07:54.303
eclipse.buildId=I20050627-1435
java.version=1.5.0_02
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=ppc, WS=carbon, NL=en_US
Framework arguments: -keyring /Users/untz/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws carbon -arch ppc -keyring
/Users/untz/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.update.configurator 2006-08-19 23:08:10.14
!MESSAGE Could not install bundle plugins/com.ibm.icu_3.4.4.1.jar No
match is available for the required execution environment:
CDC-1.0/Foundation-1.0,J2SE-1.3
!ENTRY org.eclipse.ui 2 0 2006-08-19 23:08:21.664
!MESSAGE Warnings while parsing the commands from the
'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension
points.
!SUBENTRY 1 org.eclipse.ui 2 0 2006-08-19 23:08:21.666
!MESSAGE Commands need a name: plug-in='org.rubypeople.rdt.ui',
commandId='org.rubypeople.rdt.ui.edit.text.ruby.comment'.
!SUBENTRY 1 org.eclipse.ui 2 0 2006-08-19 23:08:21.667
commandId='org.rubypeople.rdt.ui.edit.text.ruby.uncomment'.
commandId='org.rubypeople.rdt.ui.edit.text.ruby.content.assi st.proposals'.
java.lang.NoClassDefFoundError:
org/eclipse/update/operations/IInstallFeatureOperation
at org.eclipse.update.ui.UpdateJob.getUpdates(UpdateJob.java:25 6)
at
org.eclipse.update.internal.scheduler.UpdateJobChangeAdapter .done(UpdateJobChangeAdapter.java:35)
at
org.eclipse.core.internal.jobs.JobListeners$3.notify(JobList eners.java:39)
at
org.eclipse.core.internal.jobs.JobListeners.doNotify(JobList eners.java:96)
at org.eclipse.core.internal.jobs.JobListeners.done(JobListener s.java:158)
at org.eclipse.core.internal.jobs.JobManager.endJob(JobManager. java:477)
at org.eclipse.core.internal.jobs.WorkerPool.endJob(WorkerPool. java:100)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:92)
at org.osgi.util.tracker.ServiceTracker.<init>(ServiceTracker.java:162)
at
org.eclipse.update.internal.core.UpdateCore.getPackageAdmin( UpdateCore.java:315)
at
org.eclipse.update.internal.core.SiteStatusAnalyzer.status(S iteStatusAnalyzer.java:223)
at
org.eclipse.update.internal.core.SiteStatusAnalyzer.getStatu s(SiteStatusAnalyzer.java:110)
at
org.eclipse.update.internal.core.SiteStatusAnalyzer.getFeatu reStatus(SiteStatusAnalyzer.java:131)
at
org.eclipse.update.internal.core.SiteLocal.getFeatureStatus( SiteLocal.java:354)
at
org.eclipse.update.internal.search.UpdatesSearchCategory$Upd ateQuery.isBroken(UpdatesSearchCategory.java:181)
at
org.eclipse.update.internal.search.UpdatesSearchCategory$Upd ateQuery.run(UpdatesSearchCategory.java:219)
at
org.eclipse.update.search.UpdateSearchRequest.searchOneSite( UpdateSearchRequest.java:381)
at
!SESSION 2006-08-19 23:15:00.930
!ENTRY org.eclipse.update.configurator 2006-08-19 23:15:19.705
!ENTRY org.eclipse.ui 2 0 2006-08-19 23:15:31.290
points.
!SUBENTRY 1 org.eclipse.ui 2 0 2006-08-19 23:15:31.291
FUDForum. Page generated in 0.10104 seconds
