Home » Eclipse Projects » Eclipse Platform » Plugin parameters
Plugin parameters [message #166315] Fri, 05 December 2003 09:27
I have a requirement to pass a parameter (a single integer) to my plugin
when it is created. I would like to do this via the plugin's manifest
file. The research I have done suggests that I could probably achieve
this by defining extension points for the plugin. Doing this seems a
little bit of an overkill for what I want to achieve (defining the schema
and so forth). Is there an easier way?
Thanks.
James
Previous Topic:Kindly vote for this bug
Next Topic:Off Topic - observation on Java approach to building GUI's
Current Time: Sat Jul 26 14:12:27 EDT 2025
Powered by FUDForum. Page generated in 0.03205 seconds
