Home » Modeling » Epsilon » [EWL] How to order selected elements
[EWL] How to order selected elements [message #1660754] Mon, 09 March 2015 06:18 Go to next message
Hi all,
I work on wizard, that creats a generalization link between 2 classes.
my guard section is
guard{
var class1 : ecore::EClass;
var class2 : ecore::EClass;
if (self.isTypeOf (Collection) and self.size() = 2
and self.forAll(s|s.isTypeOf(ecore::EClass))){
class1 = self.at(0);
class2 = self.at(1);
return class1.isDefined() and class2.isDefined();
I want to create a link from class1 to class2, but when I selected 2 elements in the model - they are ordered in Collection not in the way I have chosen them (but alphabetically).
Example: classes A and B in the model
try to select A then B - Collection:(A,B)
try to select B then A - Collection:(A,B) also
I also tried to use .last() method and result was the same
How can I overcome it?
Re: [EWL] How to order selected elements [message #1662462 is a reply to message #1660754] Mon, 09 March 2015 22:44 Go to previous messageGo to next message
Hi Daria,
Unfortunately, the EMF editor does not preserve the order in which elements were selected (this is a more general issue [1]) so I'm afraid there's not much we can do about this.
Dimitris
[1] http://stackoverflow.com/questions/12977794/get-the-order-of-selection-from-an-istructuredselection
[Updated on: Mon, 09 March 2015 22:45] by Moderator
Re: [EWL] How to order selected elements [message #1663472 is a reply to message #1662462] Tue, 10 March 2015 08:44 Go to previous message
Thanks a lot, Dimitris!
Previous Topic:[EGL][Solved] Using EGL to generate another EGL script
Next Topic:[ETL] [Solved] - model output empty
Current Time: Sun Jul 20 20:14:09 EDT 2025
Powered by FUDForum. Page generated in 0.04085 seconds
