Home » Modeling » GMF (Graphical Modeling Framework) » Link to Link Connection - Problems
Link to Link Connection - Problems [message #165852] Wed, 19 December 2007 05:26 Go to next message
Originally posted by: david.s58.hotmail.fr
Hi everybody !
I experience a problem by creating a link to link connection.
I think the link mapping and the model mapping is done correctly. However,
when I create a link to link connection, and if I want to delete it after,
it is not working.
After a F5 the link-to-link connection is recreated automatically. ( even
if I deleted it before )
I saw there is a bug, but mine seems to be different :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=180786
If anyone has an idea, please feel free to explain me !
again thank you for this board, it helps a lot...And sorry for my english
Re: Link to Link Connection - Problems [message #165907 is a reply to message #165852] Wed, 19 December 2007 08:02 Go to previous messageGo to next message
NB : A node to link connection has the same problems. I try delete it in
the graphical editor but it reappears.
Re: Link to Link Connection - Problems [message #166114 is a reply to message #165907] Thu, 20 December 2007 08:58 Go to previous messageGo to next message
nobody has a solution to this problem ? When I delete the links, they
reappear...
Re: Link to Link Connection - Problems [message #166122 is a reply to message #166114] Thu, 20 December 2007 09:13 Go to previous messageGo to next message
It seems that your editor is synchronized with your underlying domain
model (property 'Synchronized' in the GenDiagram element of your
*.gmfgen file). In this case, a "Delete from Diagram" action would only
delete the graphical instance of your link, but when refreshing your
editor using F5, the link may reappear (note that this behavior is
strange as the "Delete From Diagram" action should be disabled in the
case of a synchronized editor). You should either perform a "Delete From
Model" action to completely remove the link from your model and its
graphical occurences. Hope it helps.
> reappear...
Re: Link to Link Connection - Problems [message #166591 is a reply to message #166122] Wed, 02 January 2008 12:30 Go to previous messageGo to next message
Originally posted by: alexpgwag.ig.com.br
Thanks Jacques Lescot!
I was facing the same problem, that Dave has related. I have a link to
link, when I delete it and press F5 the link was recreated. The tip to
delete from Model really works , I click with the second button of the
mouse and press delete from Model and the link was not recreated again.
But I want to know if there is a way to delete the link from diagram and
from the model using delete only?!
>> reappear...
Re: Link to Link Connection - Problems [message #166664 is a reply to message #166591] Thu, 03 January 2008 05:37 Go to previous messageGo to next message
I don't think this is registered, but a CTRL+DEL shortcut would be
reasonable to perform a "Delete From Model".
Howevere there are many bugs related to the way of defining its own
keybindings : see https://bugs.eclipse.org/bugs/show_bug.cgi?id=159850,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=134495 and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163697 which are all
targeted for the 2.1 release.
Alex Pinheiro a écrit :
> Hello,
> Regards,
>> only delete the graphical instance of your link, but when refreshing
>> your editor using F5, the link may reappear (note that this behavior
>> is strange as the "Delete From Diagram" action should be disabled in
>> the case of a synchronized editor). You should either perform a
>> "Delete From Model" action to completely remove the link from your
>> model and its graphical occurences. Hope it helps.
>>> reappear...
Re: Link to Link Connection - Problems [message #166672 is a reply to message #166591] Thu, 03 January 2008 05:40 Go to previous message
Thank you ( merci ? ) jacques, your explanation is working fine !
Previous Topic:Connection length in pixels, howto get that info?
Next Topic:Open request eaten problem
Current Time: Fri Sep 19 07:11:27 EDT 2025
Powered by FUDForum. Page generated in 0.25910 seconds
