Link to Link Connection - Problems [message #165852] |
Wed, 19 December 2007 05:26  |
Originally posted by: david.s58.hotmail.fr
Hi everybody !
I experience a problem by creating a link to link connection.
I think the link mapping and the model mapping is done correctly. However,
when I create a link to link connection, and if I want to delete it after,
it is not working.
After a F5 the link-to-link connection is recreated automatically. ( even
if I deleted it before )
I saw there is a bug, but mine seems to be different :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=180786
If anyone has an idea, please feel free to explain me !
again thank you for this board, it helps a lot...And sorry for my english
Re: Link to Link Connection - Problems [message #166591 is a reply to message #166122] |
Wed, 02 January 2008 12:30   |
Originally posted by: alexpgwag.ig.com.br
Thanks Jacques Lescot!
I was facing the same problem, that Dave has related. I have a link to
link, when I delete it and press F5 the link was recreated. The tip to
delete from Model really works , I click with the second button of the
mouse and press delete from Model and the link was not recreated again.
But I want to know if there is a way to delete the link from diagram and
from the model using delete only?!
Jacques LESCOT wrote:
> It seems that your editor is synchronized with your underlying domain
> model (property 'Synchronized' in the GenDiagram element of your
> *.gmfgen file). In this case, a "Delete from Diagram" action would only
> delete the graphical instance of your link, but when refreshing your
> editor using F5, the link may reappear (note that this behavior is
> strange as the "Delete From Diagram" action should be disabled in the
> case of a synchronized editor). You should either perform a "Delete From
> Model" action to completely remove the link from your model and its
> graphical occurences. Hope it helps.
> Dave a écrit :
>> nobody has a solution to this problem ? When I delete the links, they
>> reappear...
Re: Link to Link Connection - Problems [message #166664 is a reply to message #166591] |
Thu, 03 January 2008 05:37   |
I don't think this is registered, but a CTRL+DEL shortcut would be
reasonable to perform a "Delete From Model".
Howevere there are many bugs related to the way of defining its own
keybindings : see https://bugs.eclipse.org/bugs/show_bug.cgi?id=159850,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=134495 and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163697 which are all
targeted for the 2.1 release.
Alex Pinheiro a écrit :
> Hello,
> Regards,
>> only delete the graphical instance of your link, but when refreshing
>> your editor using F5, the link may reappear (note that this behavior
>> is strange as the "Delete From Diagram" action should be disabled in
>> the case of a synchronized editor). You should either perform a
>> "Delete From Model" action to completely remove the link from your
>> model and its graphical occurences. Hope it helps.
>>> reappear...
FUDForum. Page generated in 0.06370 seconds
