| Creating project that can be used in Window and Linux environment [message #165843] |
Tue, 14 March 2006 14:27  |
Originally posted by: andre_oriani.ig.com.br
I need to create a project that can be used on Windows and Linux
environments at the same time. Both use the same files, but the paths to
access them are a little bit diferent. In Linux the paths start with
"/somefolder/" and in Windows they start with "V:". Someone told me to use
path entry variables, but when I import the project to Windows, it doesn't
work, and I cannot find where to set the variables to the correct paths.
Thanks for your attention,
André Oriani
| Re: Creating project that can be used in Window and Linux environment [message #166046 is a reply to message #165843] |
Fri, 17 March 2006 15:42  |
Originally posted by: RocketLinuxNOJUNK.nojunkrocketcomp.com.au
On Wed, 15 Mar 2006 05:27:22 +1000, André Oriani <andre_oriani@ig.com.br>
wrote:
> use path entry variables, but when I import the project to Windows, it
> doesn't work, and I cannot find where to set the variables to the
> correct paths.
> André Oriani
If you are using stdc library, console programs CAN be nearly 100%
source-compatible (with some exceptions). However, there are circumstances
when you have to determine which OS you are targetting.
There are some predefined contants you can use eg
#ifdef _WIN32
/// windows stuff
#else
/// linux stuff
#endif
FUDForum. Page generated in 0.03497 seconds
