Home » Language IDEs » Java Development Tools (JDT) » builder/nature order
builder/nature order [message #165703] Wed, 23 June 2004 18:45 Go to next message
Originally posted by: zero_law.yahoo.com
Hey again everyone :)
Is there a known bug in Eclipse 3.0RC2 for executing builders that are
associated with a project in an incorrect order?
I have two builders that I've created, one goes BEFORE the java build,
and the other after. The problem is -- it seems that eclipse is calling
the java builder before either of mine, then calling mine.. is this
intended behaviour or did I miss something?
Here's a snip of the buildSpec from my .project file:
<buildSpec>
<buildCommand>
<name>org.jboss.ide.eclipse.jdt.aop.ui.AopProjectPreBuilder </name>
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<name>org.eclipse.jdt.core.javabuilder</name>
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<name>org.jboss.ide.eclipse.jdt.aop.ui.AopProjectBuilder</name >
<arguments>
</arguments>
</buildCommand>
</buildSpec>
Also, putting my project nature before or after the java project nature
doesn't seem to change this behaviour.
Thanks!
-Marshall
Re: builder/nature order [message #165719 is a reply to message #165703] Wed, 23 June 2004 20:33 Go to previous messageGo to next message
If you right click on your project > Properties and select Builders is the
order showing as correct?
Have you tried ordering the builders from this UI?
The order as shown there should be respected.
HTH
Darins
"Marshall Culpepper" <zero_law@yahoo.com> wrote in message
news:cbd14v$2fm$1@eclipse.org...
> <buildSpec>
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> </buildSpec>
> Thanks!
> -Marshall
Re: builder/nature order [message #165827 is a reply to message #165719] Thu, 24 June 2004 23:05 Go to previous messageGo to next message
Darins,
Thanks for the pointer -- I was actually mistaken. The builders are
being executed in the order I specify, but it's the behaviour of the
Java Builder that I thought would be different. Basically I'm trying to
make a first pass and invalidate/remove class files that need to be
cleanly built, and then take the fresh class files (after the java
build) and transform them.
The problem is, when I call resource.delete(true, null) or try setting
the timestamp a year back, the java builder isn't picking up that the
class files need to be re-written. Is there anyway to force the java
builder to create a clean class file from scratch for a certain class?
Thanks again!
-Marshall
> HTH
> Darins
>><buildSpec>
>><buildCommand>
>><arguments>
>></arguments>
>></buildCommand>
>><buildCommand>
>><arguments>
>></arguments>
>></buildCommand>
>><buildCommand>
>><arguments>
>></arguments>
>></buildCommand>
>></buildSpec>
>>Thanks!
>>-Marshall
Re: builder/nature order [message #165833 is a reply to message #165827] Fri, 25 June 2004 01:37 Go to previous messageGo to next message
I would expect that deleting the .class file would force a rebuild.
But if you are attempting to do this from a builder I do not believe it will
work as no resource change notifications go out during the build (I
think...needs checking)
HTH
Darins
news:cbg4o4$ch8$1@eclipse.org...
> Darins,
> Thanks again!
> -Marshall
the
> > HTH
> > Darins
> >><buildSpec>
> >><buildCommand>
> >><arguments>
> >></arguments>
> >></buildCommand>
> >><buildCommand>
> >><arguments>
> >></arguments>
> >></buildCommand>
> >><buildCommand>
> >><arguments>
> >></arguments>
> >></buildCommand>
> >></buildSpec>
> >>Thanks!
> >>-Marshall
Re: builder/nature order [message #165882 is a reply to message #165833] Fri, 25 June 2004 10:14 Go to previous message
Do you think there's a way to invoke the resource change notification
manually?
Thanks.. you're pointing me in the right direction =)
> HTH
> Darins
>>Darins,
>>Thanks again!
>>-Marshall
> the
>>>HTH
>>>Darins
>>>><buildSpec>
>>>><buildCommand>
>>>><arguments>
>>>></arguments>
>>>></buildCommand>
>>>><buildCommand>
>>>><arguments>
>>>></arguments>
>>>></buildCommand>
>>>><buildCommand>
>>>><name>org.jboss.ide.eclipse.jdt.aop.ui.AopProjectBuilder </name>
>>>><arguments>
>>>></arguments>
>>>></buildCommand>
>>>></buildSpec>
>>>>Thanks!
>>>>-Marshall
Previous Topic:Automatic Java Source Backup (By File Creation)
Next Topic:order of files and dirs in package view.
Current Time: Thu Jul 17 23:41:36 EDT 2025
Powered by FUDForum. Page generated in 0.26620 seconds
