builder/nature order [message #165703] |
Wed, 23 June 2004 18:45  |
Originally posted by: zero_law.yahoo.com
Hey again everyone :)
Is there a known bug in Eclipse 3.0RC2 for executing builders that are
associated with a project in an incorrect order?
I have two builders that I've created, one goes BEFORE the java build,
and the other after. The problem is -- it seems that eclipse is calling
the java builder before either of mine, then calling mine.. is this
intended behaviour or did I miss something?
Here's a snip of the buildSpec from my .project file:
<buildSpec>
<buildCommand>
<name>org.jboss.ide.eclipse.jdt.aop.ui.AopProjectPreBuilder </name>
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<name>org.eclipse.jdt.core.javabuilder</name>
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<name>org.jboss.ide.eclipse.jdt.aop.ui.AopProjectBuilder</name >
<arguments>
</arguments>
</buildCommand>
</buildSpec>
Also, putting my project nature before or after the java project nature
doesn't seem to change this behaviour.
Thanks!
-Marshall
Re: builder/nature order [message #165827 is a reply to message #165719] |
Thu, 24 June 2004 23:05   |
Darins,
Thanks for the pointer -- I was actually mistaken. The builders are
being executed in the order I specify, but it's the behaviour of the
Java Builder that I thought would be different. Basically I'm trying to
make a first pass and invalidate/remove class files that need to be
cleanly built, and then take the fresh class files (after the java
build) and transform them.
The problem is, when I call resource.delete(true, null) or try setting
the timestamp a year back, the java builder isn't picking up that the
class files need to be re-written. Is there anyway to force the java
builder to create a clean class file from scratch for a certain class?
Thanks again!
-Marshall
Darin Swanson wrote:
> If you right click on your project > Properties and select Builders is the
> order showing as correct?
> Have you tried ordering the builders from this UI?
> The order as shown there should be respected.
> HTH
> Darins
> "Marshall Culpepper" <zero_law@yahoo.com> wrote in message
> news:cbd14v$2fm$1@eclipse.org...
>><buildSpec>
>><buildCommand>
>><arguments>
>></arguments>
>></buildCommand>
>><buildCommand>
>><arguments>
>></arguments>
>></buildCommand>
>><buildCommand>
>><arguments>
>></arguments>
>></buildCommand>
>></buildSpec>
>>Thanks!
>>-Marshall
Re: builder/nature order [message #165833 is a reply to message #165827] |
Fri, 25 June 2004 01:37   |
I would expect that deleting the .class file would force a rebuild.
But if you are attempting to do this from a builder I do not believe it will
work as no resource change notifications go out during the build (I
think...needs checking)
HTH
Darins
news:cbg4o4$ch8$1@eclipse.org...
> Darins,
> Thanks again!
> -Marshall
the
> > HTH
> > Darins
> >><buildSpec>
> >><buildCommand>
> >><arguments>
> >></arguments>
> >></buildCommand>
> >><buildCommand>
> >><arguments>
> >></arguments>
> >></buildCommand>
> >><buildCommand>
> >><arguments>
> >></arguments>
> >></buildCommand>
> >></buildSpec>
> >>Thanks!
> >>-Marshall
Re: builder/nature order [message #165882 is a reply to message #165833] |
Fri, 25 June 2004 10:14  |
Do you think there's a way to invoke the resource change notification
manually?
Thanks.. you're pointing me in the right direction =)
> HTH
> Darins
>>Darins,
>>Thanks again!
>>-Marshall
> the
>>>HTH
>>>Darins
>>>><buildSpec>
>>>><buildCommand>
>>>><arguments>
>>>></arguments>
>>>></buildCommand>
>>>><buildCommand>
>>>><arguments>
>>>></arguments>
>>>></buildCommand>
>>>><buildCommand>
>>>><name>org.jboss.ide.eclipse.jdt.aop.ui.AopProjectBuilder </name>
>>>><arguments>
>>>></arguments>
>>>></buildCommand>
>>>></buildSpec>
>>>>Thanks!
>>>>-Marshall
FUDForum. Page generated in 0.25101 seconds
