Home » Language IDEs » ServerTools (WTP) » Validate XML File: No grammar constraints detected
Validate XML File: No grammar constraints detected [message #165385] Thu, 30 March 2006 11:13 Go to next message
Originally posted by: born.oio.de
i've got a XML File with XSD (without Namespace). Sth. like that:
<page xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="../src/xml-schema/article.xsd ">
<head>head</head>
<article/>
</page>
(generated stub)
Eclipse and WTP are suggesting possible Elements (knowing the strucutre),
but if i try to validate: "The XML File is well formed. Warning: No
grammar constraints detected for the document"
Can any body tell me wy?
Thx!
Der Matze
Re: Validate XML File: No grammar constraints detected [message #165457 is a reply to message #165385] Thu, 30 March 2006 19:11 Go to previous messageGo to next message
Matthias Born wrote:
> <head>head</head>
> <article/>
> </page>
> (generated stub)
> strucutre), but if i try to validate: "The XML File is well formed.
> Warning: No grammar constraints detected for the document"
> Thx!
> Der Matze
That does sound interesting. I've never done a no namespace schema so my
insight might not be completely informed. Have you tried closing the XML
file, re-opening it and running the validator? Sometimes that works out
some of the kinks inthe editor behavior for me.
Re: Validate XML File: No grammar constraints detected [message #165464 is a reply to message #165457] Thu, 30 March 2006 23:13 Go to previous messageGo to next message
This used to work nicely a while back. I believe this is a bug
(regression) in our XML Validator. See bug 133093.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=133093
Re: Validate XML File: No grammar constraints detected [message #165488 is a reply to message #165464] Fri, 31 March 2006 04:35 Go to previous messageGo to next message
yes, craig is right.
it worked fine before wtp 1.0. (0.7 ore sth. i can't remember)
my stub was only an example for you, the original files are much more
complex. these files were opened and closed very often, so i'm shure, that
wouldn'd solve my problem.
are you shure, that adding a namespace (targetNamespace) to the schema
will solve the problem. i must know this before changing all schema and
sources.
thx!
matze
Re: Validate XML File: No grammar constraints detected [message #166404 is a reply to message #165488] Tue, 11 April 2006 12:18 Go to previous message
Things look to be working fine when a namespace is in use. I'll get this
bug fixed in the 1.5 timeframe as your scenario should work and, as you
pointed out, used to work in WTP.
Lawrence
Previous Topic:Eclipse book recommendation!
Next Topic:Window > Preferences > Web Tools > New J2EE Project.
Current Time: Sat Jul 26 08:46:08 EDT 2025
Powered by FUDForum. Page generated in 0.04259 seconds
