Home » Language IDEs » C / C++ IDE (CDT) » Prevent CDT from indexing files of the project
Prevent CDT from indexing files of the project [message #164847] Tue, 28 February 2006 10:38 Go to next message
Configuration:
Eclipse plateform:
Version: 3.1.2
Build id: M20060118-1600
CDT:
Version: 3.0.2
Build id: 200602061513
I am trying to port an existing project to Eclipse and I am facing the
following issue:
- I can not prevent the indexer from being run on files that I have
path-excluded from the project sources
This typically happens on unit tests that are located in a directory of
each block of the project. Same applies to connection tools that are then
written for a completely different environment.
I have tried to remove the entire path of the unit tests as well as the
files individually. It still runs on those.
Any suggestion?
Thank you.
Re: Prevent CDT from indexing files of the project [message #164911 is a reply to message #164847] Wed, 01 March 2006 14:50 Go to previous messageGo to next message
Originally posted by: alexfarberov.[nospam]hotmail.com
I have the same problem here. I have a standard make file project, whose
makefile copies header files to a subdirectory. The indexer picks up
these headers even though there is an Exclusion filter for the directory
containing them under C++ Project Paths | Source.
Please someone post the solution!
Alex
Louis Caron wrote:
> Configuration:
> Eclipse plateform:
> Version: 3.1.2
> CDT:
> Version: 3.0.2
> following issue:
> then written for a completely different environment.
> Any suggestion?
> Thank you.
Re: Prevent CDT from indexing files of the project [message #164952 is a reply to message #164911] Thu, 02 March 2006 06:43 Go to previous messageGo to next message
Originally posted by: arne.anka.ginguppin.de
seems to be a bug -- did you file a bug report?
On Wed, 01 Mar 2006 20:50:55 +0100, Alex Farberov
> Alex
> Louis Caron wrote:
>> Configuration:
>> Eclipse plateform:
>> Version: 3.1.2
>> CDT:
>> Version: 3.0.2
>> following issue:
>> of each block of the project. Same applies to connection tools that are
>> the files individually. It still runs on those.
>> Any suggestion?
>> Thank you.
Re: Prevent CDT from indexing files of the project [message #165238 is a reply to message #164952] Mon, 06 March 2006 03:04 Go to previous messageGo to next message
Since I am only using eclipse for C and C++ development, I am wondering if
this bug is CDT related or Eclipse related? I am going to post a bug for
CDT for the time being.
Re: Prevent CDT from indexing files of the project [message #165373 is a reply to message #165238] Tue, 07 March 2006 17:27 Go to previous message
Originally posted by: maarten.bodewes.gmail.com
> if this bug is CDT related or Eclipse related? I am going to post a bug
> for CDT for the time being.
I've not seen this in the JDT, but I am using 3.1 up till now. I'll
upgrade to 3.2 and test this. Please indeed file bug report under C++.
Can't imagine that this is untested for the JDT.
Maarten
Previous Topic:Error Parser can't extract line numbers
Next Topic:"add include"?
Current Time: Fri Sep 19 10:00:01 EDT 2025
Powered by FUDForum. Page generated in 0.04303 seconds
