Home » Modeling » EMF » EMF with Maven(org.eclipse.core.runtime.Platform (java.lang.NoClassDefFoundError))
EMF with Maven [message #1651860] Thu, 05 March 2015 09:57 Go to next message
I'm working with EMF on a non-plugin, Google AppEngine Maven based project. I have the following dependencies as stated in my pom.xml:
<version.emfcommon>2.8.0.v20120911-0500</version.emfcommon>
<version.emfecore>2.8.1.v20120911-0500</version.emfecore>
<version.emfecorexmi>2.8.0.v20120911-0500</version.emfecorexmi>
<version.emfquery>1.2.100.v200903190031_fixed</version.emfquery>
<version.emfqueryocl>2.0.0.v20091215-1624</version.emfqueryocl>
<version.ocl>3.2.1.v20120917-1739</version.ocl>
<version.oclcommon>1.0.0.v20120516-1543</version.oclcommon>
<version.oclecore>3.2.0.v20120522-1637</version.oclecore>
<version.osgi>3.8.1.v20120830-144521</version.osgi>
<version.core.runtime>3.7.0</version.core.runtime>
The project works find on the local machine but not when deployed to GAE. There I get the org.eclipse.core.runtime.Platform (java.lang.NoClassDefFoundError). How could this be? Are there any dependencies that I am somehow forgetting?
I can see all dependencies being present in the war/WEB-INF/lib folder too. There isn't a chance that a NoClassDefFoundError could arise. Here's a complete stacktrace:
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.core.runtime.Platform
at org.eclipse.ocl.common.OCLCommon.getPreference(OCLCommon.java:74)
at org.eclipse.ocl.lpg.AbstractBasicEnvironment.getValue(AbstractBasicEnvironment.java:440)
at org.eclipse.ocl.options.ParsingOptions.getValue(ParsingOptions.java:330)
at org.eclipse.ocl.AbstractEnvironment.createTypeChecker(AbstractEnvironment.java:1214)
at org.eclipse.ocl.AbstractEnvironment.getTypeChecker(AbstractEnvironment.java:1196)
at org.eclipse.ocl.AbstractEnvironment.getAdapter(AbstractEnvironment.java:1236)
at org.eclipse.ocl.util.OCLUtil.getAdapter(OCLUtil.java:102)
at org.eclipse.ocl.util.TypeUtil.getTypeCheckerAdapter(TypeUtil.java:800)
at org.eclipse.ocl.util.TypeUtil.findAttribute(TypeUtil.java:171)
at org.eclipse.ocl.AbstractEnvironment.doLookupProperty(AbstractEnvironment.java:657)
at org.eclipse.ocl.AbstractEnvironment.lookupProperty(AbstractEnvironment.java:638)
at org.eclipse.ocl.AbstractTypeResolver.findTupleType(AbstractTypeResolver.java:430)
at org.eclipse.ocl.AbstractTypeResolver.resolveTupleType(AbstractTypeResolver.java:382)
at org.eclipse.ocl.AbstractTypeResolver$ResolveSwitch.caseTupleType(AbstractTypeResolver.java:1008)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitch(TypesSwitch.java:267)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitchSuperTypes(TypesSwitch.java:117)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitchSuperTypes(TypesSwitch.java:122)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitch(TypesSwitch.java:105)
at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:69)
at org.eclipse.ocl.AbstractTypeResolver.resolve(AbstractTypeResolver.java:127)
at org.eclipse.ocl.AbstractTypeResolver$ResolveSwitch.caseCollectionType(AbstractTypeResolver.java:1003)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitch(TypesSwitch.java:168)
at org.eclipse.ocl.util.TypeUtil.resolveType(TypeUtil.java:617)
at org.eclipse.ocl.util.OCLStandardLibraryUtil.getSetType(OCLStandardLibraryUtil.java:2216)
at org.eclipse.ocl.util.OCLStandardLibraryUtil.createCollectionOperations(OCLStandardLibraryUtil.java:1754)
at org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl.build(OCLStandardLibraryImpl.java:375)
at org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl.init(OCLStandardLibraryImpl.java:205)
at org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl.<clinit>(OCLStandardLibraryImpl.java:97)
at org.eclipse.ocl.ecore.EcoreEnvironment.getOCLStandardLibrary(EcoreEnvironment.java:271)
at org.eclipse.ocl.parser.AbstractOCLAnalyzer.booleanLiteralExpCS(AbstractOCLAnalyzer.java:3041)
at org.eclipse.ocl.parser.AbstractOCLAnalyzer.primitiveLiteralExpCS(AbstractOCLAnalyzer.java:2922)
at org.eclipse.ocl.parser.AbstractOCLAnalyzer.literalExpCS(AbstractOCLAnalyzer.java:3107)
at org.eclipse.ocl.parser.AbstractOCLAnalyzer.oclExpressionCS(AbstractOCLAnalyzer.java:1983)
at org.eclipse.ocl.parser.AbstractOCLAnalyzer.invCS(AbstractOCLAnalyzer.java:1440)
at org.eclipse.ocl.parser.AbstractOCLAnalyzer.invOrDefCS(AbstractOCLAnalyzer.java:1420)
at org.eclipse.ocl.parser.OCLAnalyzer.parseInvOrDefCS(OCLAnalyzer.java:266)
at org.eclipse.ocl.internal.helper.HelperUtil.parseQuery(HelperUtil.java:164)
at org.eclipse.ocl.internal.helper.OCLHelperImpl.createQuery(OCLHelperImpl.java:176)
at org.eclipse.emf.query.ocl.conditions.AbstractOCLCondition.<init>(AbstractOCLCondition.java:211)
at org.eclipse.emf.query.ocl.conditions.BooleanOCLCondition.<init>(BooleanOCLCondition.java:149)
at org.eclipse.emf.query.ocl.conditions.BooleanOCLCondition.<init>(BooleanOCLCondition.java:107)
at org.sociotech.communitymashup.data.impl.DataSetImpl.getAttachments(DataSetImpl.java:3032)
Please let me know if there is anything additional that you may need. Looking forward to your help, thank you.
  • Attachment: Capture.PNG
    (Size: 33.60KB, Downloaded 150 times)
[Updated on: Thu, 05 March 2015 09:58] by Moderator
Re: EMF with Maven [message #1651892 is a reply to message #1651860] Thu, 05 March 2015 10:24 Go to previous messageGo to next message
Syed,
Sorry, I'm not sure how class loading works in such a context. EMF's
core runtime itself is generally designed to work stand alone without
needing the Eclipse core runtime, but I'm pretty sure that's not the
case for the rest of your dependencies and I'm doubtful that the Eclipse
platform's jars are designed to work stand alone...
On 05/03/2015 3:57 PM, Syed Rizvi wrote:
Re: EMF with Maven [message #1651905 is a reply to message #1651860] Thu, 05 March 2015 10:34 Go to previous messageGo to next message
Hi, Syed,
NoClassDefFoundError happens when a class was found (not
ClassNotFoundException) but failed to initialize after loading. So, it
seems that the Platform class is present on the classpath but some
exception happened during its initialization that caused it to become
nonviable.
So, if you can debug in the GAE environment, then you could step
through the Platform class initialization to find what the problem is.
HTH,
Christian
On 2015-03-05 14:57:05 +0000, Syed Rizvi said:
> <image>
Re: EMF with Maven [message #1651993 is a reply to message #1651905] Thu, 05 March 2015 11:37 Go to previous messageGo to next message
Hi Christian,
I do not have the source for the Platform class initialization and hence that is something beyond my reach. Or am I not following you correctly?
Ammar
Re: EMF with Maven [message #1652119 is a reply to message #1651993] Thu, 05 March 2015 13:08 Go to previous messageGo to next message
Hi, Ammar,
Yeah, sorry, that was what I meant. I don't know anything about the
GAE environment, so I don't know how difficult it might be to debug.
Christian
On 2015-03-05 16:37:39 +0000, Syed Rizvi said:
> Hi Christian,
> correctly?
> Ammar
Re: EMF with Maven [message #1653078 is a reply to message #1652119] Thu, 05 March 2015 23:30 Go to previous messageGo to next message
I expect the platform code is not designed to be run unless started as
an Equinox application so I'm not sure how what Ammar had worked
locally. I.e., how exactly was it run locally isn't clear.
On 05/03/2015 7:08 PM, Christian W. Damus wrote:
> Hi, Ammar,
> Cheers,
> Christian
>> Hi Christian,
>> correctly?
>> Thanks,
>> Ammar
Re: EMF with Maven [message #1661056 is a reply to message #1653078] Mon, 09 March 2015 09:09 Go to previous message
Hi Ed,
I spent quite some time trying to figure out where the problem might lie, but in vain Crying or Very Sad All required dependencies are present in the project under the Maven Dependencies section. The project runs as it is on the local machine, and is not started as an Equinox application (besides, GAE still doesn't allow OSGi apps).
The question that why it doesn't run when deployed still remains. I get to see two difference errors in the logs:
  1. Could not initialize class org.eclipse.core.runtime.Platform
  2. Could not initialize class org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl
Attached are their stack traces. If you need any more details, please let me know. Any help would be greatly appreciated!
[Updated on: Mon, 09 March 2015 09:12] by Moderator
Previous Topic:Doubts about autocompletion
Next Topic:Attaching properties from one Model Element to another
Current Time: Mon Jul 21 22:34:35 EDT 2025
Powered by FUDForum. Page generated in 0.08723 seconds
