Home » Eclipse Projects » Sirius » Create new representation that is unsynchronized by default
Create new representation that is unsynchronized by default [message #1651312] Thu, 05 March 2015 03:22 Go to next message
Is it possible to configure a Sirius editor such that new diagrams are initially unsynchronized?
I think the ecore editor does something like that. Even if you ecore model already contains a number of classes, creating a representation does start with an empty diagram and you have to drag classes into the diagram.
(Yes I looked in the settings but couldn't find it so far.)
Greetings,
Wilbert.
Re: Create new representation that is unsynchronized by default [message #1651410 is a reply to message #1651312] Thu, 05 March 2015 04:34 Go to previous messageGo to next message
Hi Wilbert,
You should look at [1] and [2] in section Synchronization, "Not
Synchronized" mode in your mappings should be what you look for to have
diagram empty at beginning.
[1]
https://www.eclipse.org/sirius/doc/user/diagrams/Diagrams.html#synchronized_diagram
[2] https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html
Best Regards.
Le 05/03/2015 09:22, Wilbert Alberts a écrit :
> diagram.
> Greetings,
> Wilbert.
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: Create new representation that is unsynchronized by default [message #1651493 is a reply to message #1651410] Thu, 05 March 2015 05:31 Go to previous messageGo to next message
Hi Esteban,
Thanks for your reply. So to make it clear: I should specify that each nodemapping/containermapping is unsynchronized by default?
That also implies that something like configurable synchronization behavior is not provided.
OK, I can live with this.
Greetings,
Wilbert.
Re: Create new representation that is unsynchronized by default [message #1651549 is a reply to message #1651493] Thu, 05 March 2015 06:10 Go to previous messageGo to next message
Hi Wilbert,
Le 05/03/2015 11:31, Wilbert Alberts a écrit :
> Hi Esteban,
You could also specify mappings as "Unsynchronizable". Their
synchronization state will depend on the synchronization state of the
diagram. It can be modified by the user with a right-clic on the diagram
background with the Unsynchonized menu. The synchonized status of the
diagram will be initialized regarding the value of a preference form the
preferenc page Sirius > Sirius Diagram > Synchronized mode for new
diagrams.
> Greetings,
> Wilbert.
Maxime - Obeo
Re: Create new representation that is unsynchronized by default [message #1651744 is a reply to message #1651549] Thu, 05 March 2015 08:38 Go to previous messageGo to next message
Thanks Maxime!
This was exactly what I was looking for.
Greetings,
Wilbert
Re: Create new representation that is unsynchronized by default [message #1653784 is a reply to message #1651744] Fri, 06 March 2015 06:35 Go to previous messageGo to next message
I tried the preference setting and it does work but:.... it does not seem to be persisted over an eclipse restart?
Isn't that considered to be a bug?
Wilbert.
Re: Create new representation that is unsynchronized by default [message #1654095 is a reply to message #1653784] Fri, 06 March 2015 09:32 Go to previous messageGo to next message
Hi Wilbert,
Indeed you can raise a bugzilla.
Thanks.
> Wilbert.
Re: Create new representation that is unsynchronized by default [message #1654160 is a reply to message #1654095] Fri, 06 March 2015 10:08 Go to previous message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=461600
Previous Topic:Add new node on a diagram
Next Topic:Label Position of BorderItems
Current Time: Mon Jun 16 01:50:18 EDT 2025
Powered by FUDForum. Page generated in 0.05332 seconds
