Home » Modeling » EMF » EMF Resource load from InputStream taking too long(Resource load from InputStream in Java takes approx. 20 minutes)
EMF Resource load from InputStream taking too long [message #1634807] Wed, 25 February 2015 08:13 Go to next message
I am trying to load an EMF resource from an InputStream in Java as stated in the topic and here is how the code looks:
			DataPackage.eINSTANCE.eClass();
			String nsURI = DataPackage.eINSTANCE.getNsURI();
			Resource.Factory.Registry reg = Resource.Factory.Registry.INSTANCE;
			Map<String, Object> m = reg.getExtensionToFactoryMap();
			m.put("*", new XMIResourceFactoryImpl());
			ResourceSet resSet = new ResourceSetImpl();
			resSet.getPackageRegistry().put(nsURI, DataPackage.eINSTANCE);
			//Get URL contents
			URL mashupUrl = new URL(url);
			URLConnection connection = mashupUrl.openConnection();
			connection.setConnectTimeout(15000);
			connection.setReadTimeout(600000);
			bufferedReader = new BufferedReader(new InputStreamReader(connection.getInputStream()));
			while ((inputLine = bufferedReader.readLine()) != null)
				content.append(inputLine);
			bufferedReader.close();
                        connection.getInputStream().close();
			//Get URL contents
			Resource res = resSet.createResource(URI.createURI(url));
			if(res == null) {
				throw new MashupConnectionException("Could not create emf resource", url);
			final long start = System.currentTimeMillis();
			//Load resource
			try {
				System.out.println("Resource load start: " + new Date());
				res.load(new URIConverter.ReadableInputStream(content.toString(), StandardCharsets.UTF_8.name()), null);
				System.out.println("Resource load end: " + new Date() + " Seconds elapsed: " + (System.currentTimeMillis() - start)/1000.0);
			} catch (IOException e) {
As you can see above, "content" contains the XML data retrieved from a URL: muc2014.communitymashup.net/x3/mashup
My main question: The same code used to load the resource in < 2 minutes in my previous project (which somehow got corrupted and I had no backup unfortunately). I have now reproduced this from memory, it works, but the resource loading time has increased ten folds and I am totally unable to recall what I was doing differently in my previous version of the project.
If any other resources are required, please let me know! I would really appreciate your help.
Thank you!
[Updated on: Wed, 25 February 2015 09:44] by Moderator
Re: EMF Resource load from InputStream taking too long [message #1636380 is a reply to message #1634807] Thu, 26 February 2015 01:55 Go to previous messageGo to next message
Syed,
Comments below.
On 25.02.2015 15:12, Syed Rizvi wrote:
Is this a stand alone application rather than something running in an
Eclipse IDE?
> //Get URL contents
> //Get URL contents
> if(res == null) {
> //Load resource
> try {
> res.load(new
Why is this all so complicated? I.e., why not pass an input stream
direction to load? Then it would properly respect the encoding of the
XML/XMI?
> the project.
There are often questions about which options can be used to affect the
performance of loading. You could look for such answers. Often simple
things like deferring ID resolution have a huge impact.
> Thank you!
Re: EMF Resource load from InputStream taking too long [message #1637220 is a reply to message #1636380] Thu, 26 February 2015 10:59 Go to previous messageGo to next message
Dear Ed,
Thank you for your response!
  1. This is currently running in an Eclipse IDE and will later be a stand-alone web app that will serve a dataset to its clients
  2. Correct, but passing such a big input stream to the resource.load() function would keep the stream open for a long time and the application cannot afford that since its URL fetch cannot exceed 60 seconds in duration (AppEngine restriction)
    P.S. I know connection.setReadTimeout() is set to 600,000ms instead of 60,000ms in my original message and that was a mistake
  3. I will have a look at the answers related to improvement of loading performance. But would you be so kind to suggest a few that might be most relevant, or do I need take a trial and error approach? Smile
Best regards.
Re: EMF Resource load from InputStream taking too long [message #1637750 is a reply to message #1637220] Thu, 26 February 2015 16:55 Go to previous messageGo to next message
Syed,
Comments below.
On 26.02.2015 16:59, Syed Rizvi wrote:
> Dear Ed,
Best to rely on registrations local to the resource set (which also has
a resource factory registry).
Converting it to characters without taking into account the encoding
specified in the XML/XMI itself is a bad idea.
> most relevant, or do I need take a trial and error approach? :)
I don't have my development environment available but Google turns up
things quickly:
https://www.eclipse.org/modeling/emf/docs/performance/EMFPerformanceTips.html
> Best regards.
Re: EMF Resource load from InputStream taking too long [message #1647559 is a reply to message #1637750] Tue, 03 March 2015 08:48 Go to previous messageGo to next message
Thanks Ed, using the options improved the resource loading by 200 seconds, bringing it down to about 900 seconds instead of 1100.
Though my one question remains unanswered and that is: Why does my PC complete it in such a long time when it used to do it in < 2 minutes previously (the dataset has not changed by even a single bit). There is no way I can bring it down.
I've noticed when the exact same project is run on my friend's machine with only difference of 8 vs 16 Gigs of RAM, the resource load completed in 20 seconds. It is unbelievable!
[Updated on: Tue, 03 March 2015 08:50] by Moderator
Re: EMF Resource load from InputStream taking too long [message #1647633 is a reply to message #1647559] Tue, 03 March 2015 09:33 Go to previous message
Syed,
It's hard to speculate...
> seconds, bringing it down to about 900 seconds instead of 1100. Though
> my one question remains unaswered and that is: Why does my laptop
> previously. There is no way I can bring it down. I've noticed when the
> is unbelievable!
Previous Topic:EcoreUtil.EqualityHelper and 'ordered' feature
Next Topic:org.eclipselabs.emfjson on Maven repository?
Current Time: Sat Jul 19 01:36:04 EDT 2025
Powered by FUDForum. Page generated in 0.07310 seconds
