Home » Modeling » GMF (Graphical Modeling Framework) » RCP problem
RCP problem [message #164750] Fri, 07 December 2007 09:05 Go to next message
in each test I make to generate an RCP application out of my working gmf
projects (I simply rebuild the gmfgen choosing "rcp application" when
asked) I suddendly get an error here:
Messages.NavigatorActionProvider_OpenDiagramActionName (cannot be resolved)
this is weird I remember one of the first things I made with gmf (being a
total noob) was choosing RCP app and I obtained without problems a
reduced, very cool, eclipse environment with only my widgetry on it.
What I'm missing?
Re: RCP problem [message #164890 is a reply to message #164750] Mon, 10 December 2007 11:04 Go to previous message
Originally posted by: jacob.barde.swri.org
Sounds like you generated your RCP-based code over the code-base of the
previous code generation (without RCP). As RCP doesn't use Navigator
(by default), previously generated code will have a few dangling and
"obsolete" classes are still trying to reference Navigator code.
e.g. package 'com.yourdomain.diagram.navigator' isn't generated by RCP
default gmfgen files (unless you specifically alter the gmfgen file to
have Navigator).
Most of the errors are probably trying to reference code in this package.
> a total noob) was choosing RCP app and I obtained without problems a
> What I'm missing?
Previous Topic:How can I do a node non movable?
Next Topic:Open an editor from an action
Current Time: Fri Sep 26 00:49:07 EDT 2025
Powered by FUDForum. Page generated in 0.04853 seconds
