Home » Archived » BIRT » Trying run an report with birt 2.0.1
Trying run an report with birt 2.0.1 [message #164620] Thu, 25 May 2006 09:40 Go to next message
Originally posted by: valter.neto.datasul.com.br
Hi, I'am trying to run a report as that sample example at
http://download.eclipse.org/birt/downloads/examples/scriptin g/scripteddatasource/scripteddatasource.html
but in my version 2.0.1 I have no directory "classes" under
C:\Eclipse\plugins\org.eclipse.birt.report.viewer_2.0.1\birt \WEB-INF
as show in the tutorial, on the other hand i created the dir an put my
exemple of SimpleClass but wasn't work's!!!
I trying too create a class that will populate arraylist of object that i
want show in the report, generating a .jar and save this on
C:\Eclipse\plugins\org.eclipse.birt.report.viewer_2.0.1\birt \scriptlib
so that wasn't work too!!!!
Somebody help me!!!
sry for bad english!!
Re: Trying run an report with birt 2.0.1 [message #164713 is a reply to message #164620] Thu, 25 May 2006 13:03 Go to previous messageGo to next message
Creating the classes directory should work. You can also put it in the lib
directory as a jar.
The scriptlib directory is used for custom event handlers written in Java.
Jason
"Maracuja" <valter.neto@datasul.com.br> wrote in message
news:bee41839380131dd3d799d72881c588a$1@www.eclipse.org...
> Somebody help me!!!
Re: Trying run an report with birt 2.0.1 [message #166779 is a reply to message #164713] Thu, 01 June 2006 15:21 Go to previous messageGo to next message
don't work....
Re: Trying run an report with birt 2.0.1 [message #167214 is a reply to message #166779] Fri, 02 June 2006 19:08 Go to previous message
Does the simple class from the web site work for you?
Jason
news:8e755e805b44a45c0cb4327dd9eeb9fc$1@www.eclipse.org...
> don't work....
Previous Topic:Subjdbc Plugin UI question
Next Topic:datasource properties
Current Time: Sat Jul 26 02:35:44 EDT 2025
Powered by FUDForum. Page generated in 0.04668 seconds
