Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Browser in Linux with XULRunner 10.x
SWT Browser in Linux with XULRunner 10.x [message #1628981] Sun, 22 February 2015 06:48 Go to next message
Hi Team,
I'm trying to run a small SWT application that contains only SWT Browser
in it.
I specifically want to run it with XULRunner and the FAQ in
https://www.eclipse.org/swt/faq.php#browserlinux says that I should be
able to use XULRunner 1.9.x, 3.6.x and 10.x
I've run it successfully with 1.9.x & 3.6.x but always with 10.x with
the following exception:
org.eclipse.swt.SWTError: XPCOM error 0x80004005
at org.eclipse.swt.browser.Mozilla.error(Unknown Source)
at org.eclipse.swt.browser.Mozilla.initXULRunner(Unknown Source)
at org.eclipse.swt.browser.Mozilla.create(Unknown Source)
at org.eclipse.swt.browser.Browser.<init>(Unknown Source)
Below is my environment:
1. Eclipse : 3.8.0.
2. Linux Mint : 14 (Nadia) 64bit.
3. SWT : 4.335.
4. SWT.Mozilla style used.
5. XULRunner : xulrunner-10.0.4esr.en-US.linux-i686.tar.bz2
Any help would be greatly appreciated.
Thanks & Regards,
Setya
Re: SWT Browser in Linux with XULRunner 10.x [message #1639464 is a reply to message #1628981] Fri, 27 February 2015 11:59 Go to previous messageGo to next message
Have you tried adding
-Dorg.eclipse.swt.browser.XULRunnerPath=/path/to/xulRunner
Into your launch configuration?
More details here
Re: SWT Browser in Linux with XULRunner 10.x [message #1641058 is a reply to message #1639464] Sat, 28 February 2015 06:21 Go to previous messageGo to next message
Hi Alex,
Appreciate your response.
Yes I have added the path.
FYI, this happens only on Linux, I tried the same in Win and worked.
Thanks & Regards,
Setya
> http://stackoverflow.com/questions/17994805/how-to-install-xulrunner-for-eclipse
Re: SWT Browser in Linux with XULRunner 10.x [message #1645574 is a reply to message #1641058] Mon, 02 March 2015 10:31 Go to previous message
Perhaps this might helpful then.
Setya Mising name wrote on Sat, 28 February 2015 06:21
Hi Alex,
Thanks & Regards,
Setya
Previous Topic:Download PDF file
Next Topic:Embed SWT Composite into Windows C# application
Current Time: Mon Jul 28 06:15:59 EDT 2025
Powered by FUDForum. Page generated in 0.03934 seconds
