| Building workspace takes ages [message #164472] | Tue, 08 August 2006 04:32  |  |
| Eclipse User  |  |  |  |  | Originally posted by: marc.bakker.compass-group.nl
 I work with Eclipse 3.2 and Subversion 1.3.2. I created a repository on
 the server (via LAN), I use the fsfs (not the Berkely db filesystem). My
 working directorey is located on the same server that contains the repos.
 I want to add an Eclipse project to te repository from Eclipse.
 In Eclipse I right-click the project folder, choose 'team'. I have to make
 a new folder in the repository. That works OK. The files are imported,
 then transmitted until I see a 'transfer completed' message and 'updated
 to revision xxx'. So far so good. Then Eclipse is updating the workspace
 and it doesn't stop. It takes more than 10 minutes and the progress is
 always at 0% so I have the impression nothing happens.
 Is this a bug in Eclipse / SVN or am I doing something wrong???
| Re: Building workspace takes ages [message #164488 is a reply to message #164472] | Tue, 08 August 2006 05:20  |  |
| Eclipse User  |  |  |  |  | Originally posted by: tobias.barth.web-arts.com
 marc schrieb:
 > Hello,
 > make a new folder in the repository. That works OK. The files are
 > imported, then transmitted until I see a 'transfer completed' message
 > and 'updated to revision xxx'. So far so good. Then Eclipse is updating
 > the workspace and it doesn't stop. It takes more than 10 minutes and the
 > progress is always at 0% so I have the impression nothing happens.
 I think it should be 2 or 3 times faster if You had the workspace on a
 local hard disk instead on the LAN. But even then it will take minutes.
 If You are working with large jsp projects and myeclipse, disabling the
 jsp validation will make it much quicker.
 Is here someone who can definitively tell the time difference for
 "building workspace" between a single CPU 2800MHz Pentium 4 machine and
 one of those new Core2 DUO machines?
 Greetings,
 Tobias Barth
FUDForum. Page generated in 0.10024 seconds
