Home » Language IDEs » C / C++ IDE (CDT) » How can I setup code formatter in eclipse cdt?
How can I setup code formatter in eclipse cdt? [message #164137] Mon, 20 February 2006 10:36 Go to next message
I am running on Linux Fedora.
Thank you.
Re: How can I setup code formatter in eclipse cdt? [message #164145 is a reply to message #164137] Mon, 20 February 2006 13:47 Go to previous messageGo to next message
Originally posted by: berend.chalmers.se
There are two ways I know of. The most easy is probably installing the
simple intent code:
http://softwitch.net/blog/index.php/simple-indent-code-forma tter-for-cdt/
and having this point to the intent of your preference. I use GNU indent
for C and astyle for C++.
Good luck,
Berend.
Re: How can I setup code formatter in eclipse cdt? [message #164438 is a reply to message #164145] Fri, 24 February 2006 05:23 Go to previous messageGo to next message
> simple intent code:
and the other one?
regards
Re: How can I setup code formatter in eclipse cdt? [message #164652 is a reply to message #164438] Sat, 25 February 2006 01:52 Go to previous messageGo to next message
The other one is using the plugin under indent on the following page:
http://dev.eclipse.org/viewcvs/index.cgi/cdt-home/community. html?cvsroot=Tools_Project&rev=1.10
And it uses gnu indent by default.
Berend.
>> the simple intent code:
> and the other one?
> regards
Re: How can I setup code formatter in eclipse cdt? [message #164659 is a reply to message #164652] Sat, 25 February 2006 02:16 Go to previous messageGo to next message
And there's a newer version (1.0.2) linked from here:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/cdt-home /contrib/main.html?cvsroot=Tools_Project
If you do use this one, you'll probably prefer to create a .indent.pro
file in your home directory containing all the GNU indent command line
options you like.
mike
> Berend.
> > and the other one?
> > regards
Re: How can I setup code formatter in eclipse cdt? [message #164667 is a reply to message #164145] Sat, 25 February 2006 12:38 Go to previous messageGo to next message
I tried that plugins that you suggest. But after I format the code, it
results in code which can't compile.
i have a funcion like this:
void aFunct const {
// my implmentation.
but after I format it, it becomes
void aFunct const const {
Re: How can I setup code formatter in eclipse cdt? [message #164674 is a reply to message #164667] Sat, 25 February 2006 16:54 Go to previous messageGo to next message
I just tried your code and it works fine here. I cannot see why the
indent should create the extra "const".
The GNU indent does not work for C. But again, I don't see wy it should
generate extra text.
Berend.
> void aFunct const {
Re: How can I setup code formatter in eclipse cdt? [message #164680 is a reply to message #164674] Sat, 25 February 2006 20:12 Go to previous messageGo to next message
On Sat, 2006-02-25 at 22:54 +0100, Berend van Wachem wrote:
I've seen indent do weird things from time to time...
Eh? GNU indent was made for C, was it not? The info page for GNU indent
tells me that it is made explicitly for indenting and formatting C
program source.
> Berend.
> > void aFunct const {
Re: How can I setup code formatter in eclipse cdt? [message #164688 is a reply to message #164680] Sat, 25 February 2006 22:28 Go to previous messageGo to next message
I try that. And it happens again:
here is the funciton after indent. See the extra 'const'?
bool
YBlockMap::isVerticalOverlapped () const const
return hasOverlapped (y, h);
I am running indent on linux fedora
$ indent -version
GNU indent 2.2.9
Re: How can I setup code formatter in eclipse cdt? [message #164696 is a reply to message #164688] Sun, 26 February 2006 01:25 Go to previous messageGo to next message
Well, perhaps what Berend was saying was that indent doesn't work on C++
code.
>From the BUGS section of the indent man page:
While an attempt was made to get indent working for C++, it will
not do a good job on any C++ source except the very simplest.
The const member function syntax is definitely a C++ construct, so maybe
this is where the problem is stemming from.
> bool
> $ indent -version
> GNU indent 2.2.9
Re: How can I setup code formatter in eclipse cdt? [message #164704 is a reply to message #164680] Sun, 26 February 2006 03:33 Go to previous messageGo to next message
Yes I am sorry - I meant to say GNU indent does not work for C++. Try
astyle instead then.
But even so, I cannot see why indent generates extra code. Maybe
something strange in an .ident.prr file? My .indent.pro file contains:
-i4 -npsl -di0 -bl -d0 -cli0 -npcs -nprs -nut -sai -saf -nfca -bli0 -ci4
-l140
Berend.
>>Hi,
> program source.
>>Berend.
>>>void aFunct const {
L_@~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~@
| Berend van Wachem |
| Multiphase Flow Group |
| Chalmers University of Technology |
| Please note that my email address has changed to: |
| Berend@chalmers.se |
| Please make the appropriate changes in your address |
| list. |
__@~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~@
\/______________________________________________________/
Re: How can I setup code formatter in eclipse cdt? [message #168025 is a reply to message #164704] Wed, 12 April 2006 21:59 Go to previous messageGo to next message
> -l140
> Berend.
The referenced plugin is for indent. Is there a plugin available to use
astyle?
David
Re: How can I setup code formatter in eclipse cdt? [message #168539 is a reply to message #168025] Thu, 20 April 2006 07:36 Go to previous message
> astyle?
no. you have to wrap astyle in a script to convert the parameters, set the
radiobutton to "custom" and add the astyle parameters by hand:
#!/bin/sh
unset arglist
while [ $# -gt 3 ]; do
arglist="$arglist $1"
shift
done
/usr/bin/astyle $arglist < "$1" > "$3"
Previous Topic:How to get stdout to go to console
Next Topic:How to include external API header
Current Time: Thu Sep 18 21:49:35 EDT 2025
Powered by FUDForum. Page generated in 0.04604 seconds
