Home » Eclipse Projects » GEF » How to rebuild the flow diagram sample
How to rebuild the flow diagram sample [message #164009] Sun, 16 January 2005 09:48 Go to next message
Originally posted by: wang.xin.m165.com
I want to develop a plug-in similiar with the GEF flow example. I want to
make some change to the example source code and rebuild to study how to
write the plug-in.
I read some online help and still have no idea about how to setup the
project. Can someone kindly give me an advice? (By import...?)
Wilson
Re: How to rebuild the flow diagram sample [message #164029 is a reply to message #164009] Sun, 16 January 2005 14:24 Go to previous messageGo to next message
Wilson,
One simple way is to check out the project from CVS.
http://dev.eclipse.org/cvshowto.html - should give you connect information.
Use the /home/tools path and you should find the
org.eclipse.gef.examples.flow project - check it out into your workspace
and you're ready to go.
Hope this helps,
Brian.
P.S Just in case you don't know about CVS, you can open the CVS
perspective from Window > Open Perspective > CVS Repository Exploring ...
right click in the CVS Repositories view to create a new repository
location for the above information.
Wilson Wang wrote:
> write the plug-in.
> Wilson
Re: How to rebuild the flow diagram sample [message #164097 is a reply to message #164029] Mon, 17 January 2005 10:33 Go to previous messageGo to next message
Yes, It works!
Thanks, Brian.
Previously I created a blank plug-ins project, then copy the example source
files into this directory and copy the plugin.xml from the plugin example
directory. It passed compiling but failed in running test. My knowledge
still can not figure out the reason yet...
Wilson
"Brian Fernandes" <brian.fernandes@genuitec.com> wrote in message
news:csef1j$imu$1@www.eclipse.org...
> Wilson,
information.
> Hope this helps,
> Brian.
> Wilson Wang wrote:
> > Hi,
to
> > write the plug-in.
> > Thanks,
> > Wilson
Re: How to rebuild the flow diagram sample [message #164455 is a reply to message #164097] Tue, 18 January 2005 15:41 Go to previous message
"Wilson Wang" <wang.xin@m165.com> wrote in message
news:csglsd$jc2$1@www.eclipse.org...
> Yes, It works!
> Thanks, Brian.
source
You should be using Import -> External Plug-ins and Fragments dialog for
that.
> Wilson
> > Wilson,
> information.
> > Hope this helps,
> > Brian.
> > Wilson Wang wrote:
> > > Hi,
> to
to
> > > write the plug-in.
> > > Thanks,
> > > Wilson
Previous Topic:Multi Page Palette
Next Topic:Drag and drop between AWT and SWT?
Current Time: Wed Jul 30 22:13:05 EDT 2025
Powered by FUDForum. Page generated in 0.08066 seconds
