Home » Language IDEs » ServerTools (WTP) » Existing project into WTP?
Existing project into WTP? [message #163956] Wed, 15 March 2006 07:53 Go to next message
Originally posted by: hszillat.gmail.com
Hello everyone,
I can't find a way to "import" an existing project into the "WTP",
especially associating it with an already defined Tomcat-Server, other
than to create a new "WTP-project" and copying all the files from the
old one.
I hope, someone can help me?
Bye,
HS
Re: Existing project into WTP? [message #163959 is a reply to message #163956] Wed, 15 March 2006 08:27 Go to previous messageGo to next message
Originally posted by: david.schneider.unisys.com
Just use the regular Eclipse import. I'm using a Jboss server. There are
some tricks to make it work seamlessly.
1) make sure you define your server in the Eclipse preferences before the
import.
2) If the server definition has changed, manually edit the project
..classpath to use the new server definition.
3) Do a normal Ecplipse project import.
If you forget #1 and #2, the server references will get dropped and I'm not
sure how to fix it other than rebuilding the project.
"Holger Szillat" <hszillat@gmail.com> wrote in message
news:6dfb19cc1d6b203f0d39635ee413337e$1@www.eclipse.org...
> Hello everyone,
> old one.
> Bye,
> HS
Re: Existing project into WTP? [message #164088 is a reply to message #163959] Thu, 16 March 2006 06:28 Go to previous message
Dave Schneider wrote:
Thanks! You saved the day...
Bye.
Previous Topic:Adding Projects to Tomcat's classpath
Next Topic:Convert WSAD Projects to Eclipse/WTP
Current Time: Fri Jul 18 09:11:33 EDT 2025
Powered by FUDForum. Page generated in 0.06497 seconds
