Home » Eclipse Projects » GEF » bug in Label.setTextAlignment ?
bug in Label.setTextAlignment ? [message #163950] |
Thu, 13 January 2005 18:33  |
Originally posted by: bandrews.nospam_bphnx.com
I have the following code in an edit part:
protected IFigure createFigure()
Label model = (Label) getModel();
org.eclipse.draw2d.Label label = new
org.eclipse.draw2d.Label(model.getText());
label.setOpaque(true);
label.setBackgroundColor(new
Color(null,model.getBackgroundColor()));
label.setForegroundColor(new
Color(null,model.getForegroundColor()));
label.setFont(model.getFont());
label.setTextAlignment(PositionConstants.LEFT);
return label;
I would expect the text to be left justified when I see the Label in the
editor, but it's not. It's always in the center. It's the same with
PositionConstants.RIGHT. Am I missing something here, or is this a bug?
Can someone else please try it? I am using 3.1M2.
many thanks,
B
Re: bug in Label.setTextAlignment ? [message #163998 is a reply to message #163950] |
Sat, 15 January 2005 13:36   |
Barry,
I haven't tried this, but it is possible that your Draw2D Label is only as
large as the text it contains (Therefore the text alignment won't make a
difference).
It is likely that the Draw2D Label itself is center aligned in it's parent
figure giving you the impression that the text it contains is center
aligned.
A simple way to check this out is to set the background color of the Label
to be different from the background color of it's parent.
Hope this helps,
Brian.
Barry Andrews wrote:
> return label;
> many thanks,
> B
Re: bug in Label.setTextAlignment ? [message #164159 is a reply to message #163998] |
Mon, 17 January 2005 13:29   |
Thanks for the reply. No, the label is much wider than the text. I also
tried changing the background to be different than the parent's color
and it makes no difference.
If I don't get a resolution pretty soon, I will just assume a bug and
log it. I can't imagine that my code is wrong. Aligning text should be
straight forward.
thanks,
Barry
Brian Fernandes wrote:
> Barry,
> as large as the text it contains (Therefore the text alignment won't
> make a difference).
> parent figure giving you the impression that the text it contains is
> center aligned.
> Label to be different from the background color of it's parent.
> Hope this helps,
> Brian.
>> Hi,
>> return label;
>> the editor, but it's not. It's always in the center. It's the same
>> with PositionConstants.RIGHT. Am I missing something here, or is this
>> a bug? Can someone else please try it? I am using 3.1M2.
>> many thanks,
>> B
Re: bug in Label.setTextAlignment ? [message #164166 is a reply to message #164159] |
Mon, 17 January 2005 14:36   |
Barry,
I only suggested changing the background color as a means of verifying
that your label is indeed wider than it's text, not as a fix for the
problem.
If you haven't already, please look at the javadoc for Label -
setTextAlignment and setLabelAlignment methods. Might find some answers
there.
All the best,
Brian.
D
> straight forward.
> thanks,
> Barry
>> Barry,
>> make a difference).
>> center aligned.
>> Hope this helps,
>> Brian.
>>> Hi,
>>> return label;
>>> many thanks,
>>> B
Re: bug in Label.setTextAlignment ? [message #164182 is a reply to message #164166] |
Mon, 17 January 2005 15:02   |
Ok, if I use setLabelAlignment(), it works. But what does that mean? The
docs say "Sets the Label's alignment to the passed value." Ok, that's
nice, but what does it mean? What does it align to? I am interested in
positioning the text within the label, so I would presume to use the
setTextAlignment() method. This is very confusing!
Barry
> Barry,
> problem.
> there.
> All the best,
> Brian.
> D
>> also tried changing the background to be different than the parent's
>> color and it makes no difference.
>> straight forward.
>> thanks,
>> Barry
>>> Barry,
>>> only as large as the text it contains (Therefore the text alignment
>>> won't make a difference).
>>> center aligned.
>>> Hope this helps,
>>> Brian.
>>>> Hi,
>>>> return label;
>>>> this a bug? Can someone else please try it? I am using 3.1M2.
>>>> many thanks,
>>>> B
Re: bug in Label.setTextAlignment ? [message #164203 is a reply to message #164182] |
Mon, 17 January 2005 18:08   |
Label supports both an icon and string simultaneously. The string can be
positioned above, below, left, and right of the icon. Text alignment refers
to the string's alignment with the icon, when the icon is larger than the
string.
-Randy
"Barry Andrews" <bandrews@nospam_bphnx.com> wrote in message
news:csh5lj$7he$1@www.eclipse.org...
> Barry
>> Barry,
>> problem.
>> there.
>> All the best,
>> Brian.
>> D
>>> straight forward.
>>> thanks,
>>> Barry
>>>> Barry,
>>>> make a difference).
>>>> center aligned.
>>>> Hope this helps,
>>>> Brian.
>>>>> Hi,
>>>>> return label;
>>>>> many thanks,
>>>>> B
Re: bug in Label.setTextAlignment ? [message #164242 is a reply to message #164203] |
Mon, 17 January 2005 21:12   |
Hi Randy,
I thought that's what setTextPlacement was for?
"Sets the text placement of the label relative to its icon."
Barry
> string.
> -Randy
>>Barry
>>>Barry,
>>>problem.
>>>there.
>>>All the best,
>>>Brian.
>>>D
>>>>straight forward.
>>>>thanks,
>>>>Barry
>>>>>Barry,
>>>>>make a difference).
>>>>>center aligned.
>>>>>Hope this helps,
>>>>>Brian.
>>>>>>Hi,
>>>>>> return label;
>>>>>>many thanks,
>>>>>>B
Re: bug in Label.setTextAlignment ? [message #164402 is a reply to message #164242] |
Tue, 18 January 2005 14:40  |
You're right, that's what setTextPlacement() is for. setTextAlignment() and
setIconAlignment() determine how they're aligned based on their placement.
So, say, the text is to the east of the icon, then valid icon and text
alignments are north, center, south (any other alignment will be ignored).
Notice that when you have no icon, you can get the same effect as
setLabelAlignment(EAST) by setting the text placement to south (or north)
and text alignment to left.
Go ahead and log a bug for insufficient/confusing information. We'll update
the JavaDoc.
news:cshrau$ic3$1@www.eclipse.org...
> Hi Randy,
> Barry
be
refers
the
> > string.
> > -Randy
> >>Barry
> >>>Barry,
> >>>problem.
> >>>there.
> >>>All the best,
> >>>Brian.
> >>>D
also
> >>>>straight forward.
> >>>>thanks,
> >>>>Barry
> >>>>>Barry,
only
> >>>>>make a difference).
> >>>>>center aligned.
> >>>>>Hope this helps,
> >>>>>Brian.
> >>>>>>Hi,
> >>>>>> return label;
this
> >>>>>>many thanks,
> >>>>>>B
Current Time: Sun Jul 27 01:46:00 EDT 2025
Powered by FUDForum. Page generated in 0.09946 seconds
