Home » Archived » BIRT » Is it possible to generate reports in Excel Format
Is it possible to generate reports in Excel Format [message #163921] Wed, 24 May 2006 00:59 Go to next message
hi ,
As of now we are able to generate reports in two format HTML and PDF.
Now i have a requirement to generate reports in MS Excel Foratm.
Let me know is it possible to generate reports in othere than HTML and PDF
using BIRT.
and aslo let me know is it possible to generate reports in MS Excel format.
regards
venkata
Re: Is it possible to generate reports in Excel Format [message #164501 is a reply to message #163921] Wed, 24 May 2006 22:24 Go to previous messageGo to next message
Originally posted by: qauck.msn.com
The answer is YES, venkata, check out
https://sourceforge.net/projects/tribix/ and good luck.
Shawn
venkata wrote:
> hi ,
> PDF using BIRT.
> regards
> venkata
Re: Is it possible to generate reports in Excel Format [message #164525 is a reply to message #164501] Thu, 25 May 2006 03:20 Go to previous messageGo to next message
hi , thanks for you reply,
let me know any example how to generate xls file at run time using
rptdesign file.
regards
venaktar
Re: Is it possible to generate reports in Excel Format [message #164761 is a reply to message #164525] Thu, 25 May 2006 14:07 Go to previous messageGo to next message
I try it in it looks fine.
But there are some points witch I don't understand:
1. How can I use the range support? There is no parameter in the viewer
where I can set this value.
How can I see all the information in just one page.
2. How can I activate the show grind feature.
3. How can I activate the remove blank rows feature.
I try to look up the code, but without success.
Can anybody help me?
Carlos Dias
> rptdesign file.
> regards
> venaktar
Re: Is it possible to generate reports in Excel Format [message #164883 is a reply to message #164761] Thu, 25 May 2006 22:23 Go to previous messageGo to next message
Meanwhile, the viewer doesn't expose any interface to pass any emitter
configuration in. You have to tweak the viewer source code to get this.
For use with standalone report engine, here is a doc decribes how to:
http://tribix.sourceforge.net/docs/How%20to%20use%20XLS%20em itter%20with%20BIRT%20runtime.htm
> Carlos Dias
>> rptdesign file.
>> regards
>> venaktar
Re: Is it possible to generate reports in Excel Format [message #165071 is a reply to message #163921] Fri, 26 May 2006 15:17 Go to previous messageGo to next message
Venkata? are you the same person that has worked with Fleet Manager?
sorry for off topic, but was curious.
Re: Is it possible to generate reports in Excel Format [message #166856 is a reply to message #164883] Fri, 02 June 2006 03:40 Go to previous message
Originally posted by: absrivas.yahoo.com
for showing the gridlines you can use:
xlsConfig.put("show_grid_lines",new Boolean(true) );
there are other couple of propertirs we can set are
public static final String KEY_REMOVE_EMPTY_ROW = "remove_empty_row";
public static final String KEY_SHOW_GRID_LINES = "show_grid_lines";
public static final String KEY_PAGE_RANGE = "page_range";
public static final String KEY_FIXED_COLUMN_WIDTH =
"fixed_column_width";
public static final String ALL_ODD_PAGE = "odd";
public static final String ALL_EVEN_PAGE = "even";
I got these from XlsEmitterConfig class. I haev seen show_grid_lines works
fine but for others I am not sure.
Previous Topic:getting Birt 2.1 RC4 to run on WebSphere
Next Topic:mean chart question
Current Time: Fri Sep 19 07:46:01 EDT 2025
Powered by FUDForum. Page generated in 0.03815 seconds
