Home » Eclipse Projects » GEF » CVS/ToolBarLayout getPreferredSize infinite loop
CVS/ToolBarLayout getPreferredSize infinite loop [message #163781] Wed, 12 January 2005 18:17 Go to next message
Originally posted by: nipun.walia.gmail.com
hi,
1. I am behind a firewall and cant access the Gef examples on CVS. Are
they available online somewhere ?
2. I have created a simple figure under a container figure that uses
vertical ToolbarLayout. If I don't override getPreferredSize the child
figure does not show up. If I override getPreferredSize and return a
dimension of say (100,100), the figure shows up but some infinite loop
kicks in. What am I doing wrong ? I tried setMinimumSize() and setSize()
but the ToolbarLayout overrides the set values.
any help would be appreciated.
thanks
Nipun
Re: CVS/ToolBarLayout getPreferredSize infinite loop [message #163805 is a reply to message #163781] Thu, 13 January 2005 11:56 Go to previous message
1. Under the downloads section on our webpage.
2. What is the infinite loop? Stack trace? (You can pause a program with
the Eclipse debugger.)
"Nipun Walia" <nipun.walia@gmail.com> wrote in message
news:cs4b5k$o5j$1@www.eclipse.org...
> hi,
> thanks
> Nipun
Previous Topic:NPE in flowExample
Next Topic:Up to date eclipse 3.0 GEF/EMF Example?
Current Time: Wed Oct 22 09:55:36 EDT 2025
Powered by FUDForum. Page generated in 0.05305 seconds
