Home » Newcomers » Newcomers » Do I need ResourceTransfer class? If so, where is it in Eclipse vrs 3.2.0?
Do I need ResourceTransfer class? If so, where is it in Eclipse vrs 3.2.0? [message #163677] Thu, 03 August 2006 08:14 Go to next message
Originally posted by: developerj2.yahoo.gr
I am a new user of Eclipse vrs 3.2.0 and I am trying to implement a Drag &
Drop functionality between two trees, where each tree is in a different
view. The elements of my tree are custom objects (of class Node, which is an
implementation of IAdaptable). I have read all about TreeViewer,
ContentProvider, and domain objects and how they work together. What I am
trying to do is quite similar to what has been posted to a thread in the
past, http://dev.eclipse.org/newslists/news.eclipse.tools/msg31775 .html
I am not sure if I should implement ByteArrayTransfer for the transfer of
the Nodes (leaf Nodes), or if it's possible to just use ResourceTransfer to
do the job. Here is the code for my custom Transfer class, which doesn't
really do anything because I didn't implement javaToNative and nativeToJava,
as I am not sure if it's possible to map the data I am converting to a
byte[],:
public class NodeTransfer extends ByteArrayTransfer {
private static final String MYTYPENAME = "my_type_name";
private static final int MYTYPEID = registerType(MYTYPENAME);
private static NodeTransfer _instance = new NodeTransfer();
private NodeTransfer() {}
public static NodeTransfer getInstance () {
return _instance;
protected int[] getTypeIds() {
// TODO Auto-generated method stub
return null;
protected String[] getTypeNames() {
return null;
here is my Node class:
public class Node implements IAdaptable {
private String name;
private ParentNode parent;
The question is can I use the ResourceTransfer class to do the job, i.e.
viewer.addDragSupport(operations, new Transfer[] {
ResourceTransfer.getInstance() }, new DragSourceListener() {...
If so, where is the ResourceTransfer class? It seems that it's not at
org.eclipse.ui.part in my IDE, and when I hit Ctrl+Space on the
ResourceTransfer, Eclipse won't find it anything at all for this class!
Re: Do I need ResourceTransfer class? If so, where is it in Eclipse vrs 3.2.0? [message #163685 is a reply to message #163677] Thu, 03 August 2006 08:23 Go to previous message
Thank in advance for your help!
"Hector K." <developerj2@yahoo.gr> wrote in message
news:easpbt$d08$1@utils.eclipse.org...
> Hello,
> an implementation of IAdaptable). I have read all about TreeViewer,
> to do the job. Here is the code for my custom Transfer class, which
> doesn't really do anything because I didn't implement javaToNative and
> nativeToJava, as I am not sure if it's possible to map the data I am
> converting to a byte[],:
> return _instance;
> @Override
> return null;
> @Override
> return null;
Previous Topic:Editor Usage
Next Topic:Re: Eclipes deleted my files. HELP!!!
Current Time: Sun Jul 27 12:53:00 EDT 2025
Powered by FUDForum. Page generated in 0.07922 seconds
