Home » Archived » BIRT » library view
library view [message #163148] Fri, 19 May 2006 19:46 Go to next message
Originally posted by: wohlgemuth.ucdavis.edu
hi it happens that I just created my first library mostly including sql
datasets need for my daily work.
but now i can't explore my library :(
i "said" use it in my report and i see it in my report, but don't see any
library content. mayvbe a bug?
using eclipse 3.2 and the rc4 of birt.
regards
Re: library view [message #163317 is a reply to message #163148] Mon, 22 May 2006 05:27 Go to previous messageGo to next message
I donno whether this wud help or not but the way we do is....we make a new
library using File->New->Library and add Datasets/DataSources to it. Then we
DRAG the required DataSets/Sources from "Library Explorer" to "Outline"
view of the rptdesign file. This works perfectly.
Also please check if the required Datasource u want is added first to the
rptdesign before adding Datasets.
"gert wohlgemuth" <wohlgemuth@ucdavis.edu> wrote in message
news:e4lld2$fgg$1@utils.eclipse.org...
> regards
Re: library view [message #163497 is a reply to message #163317] Mon, 22 May 2006 13:36 Go to previous messageGo to next message
yes i know,
but in the rc2 the explorer seems not to work.
before it was exactly this way. But now I can't find any way to import my
lib stuff. The library explorer always shows empty. No errors, no log
errors.
just nothing :(
and i will be doomed if i have to copy paste all my datasources, styles and
so...
g.
"Girish" <girisha@cybage.com> wrote in message
news:e4s08f$8eg$1@utils.eclipse.org...
>we DRAG the required DataSets/Sources from "Library Explorer" to "Outline"
>> regards
Re: library view [message #163595 is a reply to message #163497] Mon, 22 May 2006 18:24 Go to previous messageGo to next message
Since BIRT2.1RC2 there was a change concerning resource files. You have to
set the resource folder under
Window > Preferences > Report Design (RC3) / BIRT (RC2) > Resource
Your libraries should reside in this directory.
Hope that helps.
"gert wohlgemuth" <wohlgemuth@ucdavis.edu> schrieb im Newsbeitrag
news:e4sss7$jhu$1@utils.eclipse.org...
> yes i know,
> errors.
> just nothing :(
> and so...
> g.
>>> any library content. mayvbe a bug?
>>> regards
Re: library view [message #163610 is a reply to message #163595] Mon, 22 May 2006 19:21 Go to previous message
ok thx, this helps a lot.
now it works. I just wished i would know this a long time before...
where do you find this infos?
g.
"Der Spunk" <spunk_der@hotmail.com> wrote in message
news:e4tdqb$eep$1@utils.eclipse.org...
> Hope that helps.
>> yes i know,
>> errors.
>> just nothing :(
>> and so...
>> g.
>>>new library using File->New->Library and add Datasets/DataSources to it.
>>>Then we DRAG the required DataSets/Sources from "Library Explorer" to
>>>"Outline" view of the rptdesign file. This works perfectly.
>>> the rptdesign before adding Datasets.
>>>> regards
Previous Topic:problem with a query/graph
Next Topic:search creteria
Current Time: Sat Jul 19 00:50:55 EDT 2025
Powered by FUDForum. Page generated in 0.26134 seconds
