Home » Eclipse Projects » Lyo » Problem accessing /OSLC4JQualityManagement/services/testPlans. Reason: Not Found(HTTP ERROR: 404)
Problem accessing /OSLC4JQualityManagement/services/testPlans. Reason: Not Found [message #1635048] Wed, 25 February 2015 10:40 Go to next message
I did import the projects for Quality management, then I try to run the Quality Management sample provider, but when I go to the url (l....OSLC4JQualityManagement/services/testPlans), i received HTTP ERROR 404.
Any help ?
Thanks !
[Updated on: Wed, 25 February 2015 10:41] by Moderator
Re: Problem accessing /OSLC4JQualityManagement/services/testPlans. Reason: Not Found [message #1635526 is a reply to message #1635048] Wed, 25 February 2015 16:02 Go to previous message
Can you do a git pull and try again? I believe I've fixed the problem.
https://git.eclipse.org/r/#/c/42694/
Sam
Previous Topic:Resources with multiple rdf:type predicates
Next Topic:HTTP ERROR 500 Problem accessing /OSLC4JStockQuote/stockQuotes. Reason:
Current Time: Sat Jul 19 03:13:54 EDT 2025
Powered by FUDForum. Page generated in 0.03392 seconds
