Home » Eclipse Projects » GEF » Error
Error [message #163196] Tue, 04 January 2005 22:52 Go to next message
Originally posted by: pankajsanghi.hotmail.com
hi everybody,
We have developed a which extends the functionality of GEF Logic Example
so as to support data storate and retrieval in the model classes. We are
doing this retrieval and storage of data in model classes through jface
dialogs which contains SWT widgets. As of now, we run this plugin as
'Runtime Workbench'.
While the application is running perfectly, sometime it throws the
exception as given below and my whole run time workbench window gets
closed. I am giving the exception trace as below. To my surprise this
exception trace nowhere mentions the name of my classes. Exception is
thrown under three categories as
1. org.eclipse.swt.SWTError: No more handles
2. Dialog open exception:org.eclipse.swt.SWTError: No more handles
3. Fatal error happened during workbench emergency close.
Can you please help me with the possible cause of this error and how I can
handle it without knowing the class where it is generated. Should I use
try catch block to handle it??
Please help me in resolving the problem??
I had posted a similar query on SWT forum also and got a reply that this
error occurs when platform does not support a particular component. Which
component may be unsupported on this platform?? Other than GEF Logic
Example's components my plugin uses jdom and oracle parser also.
regards
Pankaj Sanghi
at org.eclipse.swt.SWT.error(SWT.java:2715)
at org.eclipse.swt.SWT.error(SWT.java:2614)
at org.eclipse.swt.SWT.error(SWT.java:2585)
at org.eclipse.swt.graphics.Image.internal_new_GC(Image.java:17 23)
at org.eclipse.swt.graphics.GC.<init>(GC.java:120)
at org.eclipse.swt.graphics.GC.<init>(GC.java:87)
at
org.eclipse.draw2d.BufferedGraphicsSource.getGraphics(Buffer edGraphicsSource.java:76)
at
org.eclipse.draw2d.DeferredUpdateManager.getGraphics(Deferre dUpdateManager.java:108)
at
org.eclipse.draw2d.DeferredUpdateManager.repairDamage(Deferr edUpdateManager.java:194)
at
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:134)
at
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:118)
at org.eclipse.draw2d.LightweightSystem.paint(LightweightSystem .java:211)
at
org.eclipse.draw2d.LightweightSystem$4.handleEvent(Lightweig htSystem.java:115)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:820)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:805)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:80 3)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3001 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3282 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:14 75)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2380)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1363)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1334)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:253)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:97)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:307)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:256)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
at org.eclipse.swt.graphics.Image.init(Image.java:1564)
at org.eclipse.swt.graphics.Image.init(Image.java:1689)
at org.eclipse.swt.graphics.Image.<init>(Image.java:628)
at org.eclipse.swt.widgets.Decorations.setImages(Decorations.ja va:878)
at org.eclipse.swt.widgets.Decorations.setImages(Decorations.ja va:947)
at org.eclipse.jface.window.Window.configureShell(Window.java:2 91)
at
org.eclipse.jface.dialogs.MessageDialog.configureShell(Messa geDialog.java:159)
at org.eclipse.jface.window.Window.createShell(Window.java:408)
at org.eclipse.jface.window.Window.create(Window.java:347)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:924)
at
org.eclipse.ui.internal.ide.dialogs.InternalErrorDialog.open (InternalErrorDialog.java:67)
at
org.eclipse.ui.internal.ide.dialogs.InternalErrorDialog.open Question(InternalErrorDialog.java:173)
at
org.eclipse.ui.internal.ide.IDEExceptionHandler.openQuestion Dialog(IDEExceptionHandler.java:151)
at
org.eclipse.ui.internal.ide.IDEExceptionHandler.handleExcept ion(IDEExceptionHandler.java:83)
at
org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor.eventLoopExc eption(IDEWorkbenchAdvisor.java:241)
at
org.eclipse.ui.internal.ExceptionHandler.handleException(Exc eptionHandler.java:62)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1367)
at
at
at
at
at org.eclipse.swt.graphics.Image.<init>(Image.java:279)
at org.eclipse.swt.widgets.ToolItem.createDisabledImage(ToolIte m.java:195)
at org.eclipse.swt.widgets.ToolItem.updateImages(ToolItem.java: 794)
at org.eclipse.swt.widgets.ToolItem.setEnabled(ToolItem.java:55 6)
at
org.eclipse.jface.action.StatusLine.setCancelEnabled(StatusL ine.java:386)
at
org.eclipse.jface.action.StatusLineManager.setCancelEnabled( StatusLineManager.java:228)
at
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:609)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:1588)
at
org.eclipse.ui.internal.EditorManager.runProgressMonitorOper ation(EditorManager.java:845)
at org.eclipse.ui.internal.EditorManager.saveAll(EditorManager. java:947)
at org.eclipse.ui.internal.Workbench$11.run(Workbench.java:508)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:608)
at org.eclipse.core.runtime.Platform.run(Platform.java:758)
at org.eclipse.ui.internal.Workbench.saveAllEditors(Workbench.j ava:482)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:4 08)
at org.eclipse.ui.internal.Workbench.access$8(Workbench.java:39 9)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:571)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:569)
at
org.eclipse.ui.internal.WorkbenchConfigurer.emergencyClose(W orkbenchConfigurer.java:150)
at
org.eclipse.ui.internal.ide.IDEExceptionHandler.closeWorkben ch(IDEExceptionHandler.java:104)
at
org.eclipse.ui.internal.ide.IDEExceptionHandler.handleExcept ion(IDEExceptionHandler.java:84)
at
at
at
at
at
at
Re: Error [message #163213 is a reply to message #163196] Wed, 05 January 2005 10:37 Go to previous messageGo to next message
This has been fixed in GEF 3.0.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=53632
"Pankaj Sanghi" <pankajsanghi@hotmail.com> wrote in message
news:crfo9u$9mh$1@www.eclipse.org...
> hi everybody,
> regards
> Pankaj Sanghi
> at
..java:76)
> at
ava:108)
> at
java:194)
> at
..java:134)
> at
..java:118)
> at
5)
> at
> at
java:307)
> at
> at
> at
9)
> at
alog.java:67)
> at
> at
> at
Handler.java:83)
> at
> at
va:62)
> at
> at
java:307)
> at
> at
> at
> at
r.java:228)
> at
> at
ger.java:845)
> at
:608)
> at
er.java:150)
> at
andler.java:104)
> at
Handler.java:84)
> at
> at
va:62)
> at
> at
java:307)
> at
> at
Re: Error [message #163223 is a reply to message #163213] Thu, 06 January 2005 01:00 Go to previous messageGo to next message
We are using the GEF 3.0 only as used by GEF Logic Example. But problem is
still present.
Can you please tell me how should we deal with it??
thanks and regards
Pankaj Sanghi
>> hi everybody,
>> regards
>> Pankaj Sanghi
>> at
> ..java:76)
>> at
> ava:108)
>> at
> java:194)
>> at
> ..java:134)
>> at
> ..java:118)
>> at
> 5)
>> at
>> at
> java:307)
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
> 9)
>> at
> alog.java:67)
>> at
>> at
>> at
> Handler.java:83)
>> at
>> at
> va:62)
>> at
>> at
> java:307)
>> at
>> at
>> at
>> at
> r.java:228)
>> at
>> at
> ger.java:845)
>> at
> :608)
>> at
> er.java:150)
>> at
> andler.java:104)
>> at
> Handler.java:84)
>> at
>> at
> va:62)
>> at
>> at
> java:307)
>> at
>> at
Re: Error [message #163231 is a reply to message #163223] Thu, 06 January 2005 09:33 Go to previous messageGo to next message
Can you please tell me how should I check the version of GEF plugin I am
using. Its plugin.xml calls its version as 3.0.0 but readme file refers as
2.1.1
Which one of the two is correct??
thanks and regards
Pankaj Sanghi
> still present.
> thanks and regards
> Pankaj Sanghi
>>> hi everybody,
>>> regards
>>> Pankaj Sanghi
>>> at
>> ..java:76)
>>> at
>> ava:108)
>>> at
>> java:194)
>>> at
>> ..java:134)
>>> at
>> ..java:118)
>>> at
>> 5)
>>> at
>>> at
>> java:307)
>>> at
>>> at
>>> at
>> 9)
>>> at
>> alog.java:67)
>>> at
>>> at
>>> at
>> Handler.java:83)
>>> at
>>> at
>> va:62)
>>> at
>>> at
>> java:307)
>>> at
>>> at
>>> at
>>> at
>> r.java:228)
>>> at
>>> at
>> ger.java:845)
>>> at
>> :608)
>>> at
>> er.java:150)
>>> at
>> andler.java:104)
>>> at
>> Handler.java:84)
>>> at
>>> at
>> va:62)
>>> at
>>> at
>> java:307)
>>> at
>>> at
Re: Error [message #163241 is a reply to message #163231] Thu, 06 January 2005 12:13 Go to previous messageGo to next message
Just look at BufferedGraphicsSource#getGraphics() and see if it has the fix
for Bug 53632.
* Bugzilla 53632 - Attempts to create large images on some platforms will
fail.
* When this happens, do not use double-buffering for painting.
try {
imageBuffer = new Image(null, inUse.width, inUse.height);
} catch (SWTError noMoreHandles) {
imageBuffer = null;
} catch (IllegalArgumentException tooBig) {
imageBuffer = null;
news:crji7t$iro$1@www.eclipse.org...
> 2.1.1
> thanks and regards
> Pankaj Sanghi
is
> > still present.
> > thanks and regards
> > Pankaj Sanghi
> >>> hi everybody,
Example
are
jface
can
use
this
Which
> >>> regards
> >>> Pankaj Sanghi
> >>> at
> >> ..java:76)
> >>> at
> >> ava:108)
> >>> at
> >> java:194)
> >>> at
> >> ..java:134)
> >>> at
> >> ..java:118)
> >>> at
> >>> at
> >> 5)
> >>> at
> >>> at
> >>> at
> >>> at
> >> java:307)
> >>> at
> >>> at
> >>> at
> >> 9)
> >>> at
> >> alog.java:67)
> >>> at
> >>> at
> >>> at
> >> Handler.java:83)
> >>> at
> >>> at
> >> va:62)
> >>> at
> >>> at
> >>> at
> >>> at
> >> java:307)
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> >> r.java:228)
> >>> at
> >>> at
> >>> at
> >> ger.java:845)
> >>> at
> >>> at
> >> :608)
> >>> at
> >>> at
> >>> at
> >> er.java:150)
> >>> at
> >> andler.java:104)
> >>> at
> >> Handler.java:84)
> >>> at
> >>> at
> >> va:62)
> >>> at
> >>> at
> >>> at
> >>> at
> >> java:307)
> >>> at
> >>> at
Re: Error [message #163394 is a reply to message #163241] Mon, 10 January 2005 06:25 Go to previous messageGo to next message
Hi all,
yes......pratik.......this code is present in BufferedGraphicsSource.
But this exception is still coming in my application. What can be the
problem??
thanks and regards
Pankaj Sanghi
> for Bug 53632.
> fail.
> try {
> imageBuffer = null;
> imageBuffer = null;
>> 2.1.1
>> thanks and regards
>> Pankaj Sanghi
> is
>> > still present.
>> > thanks and regards
>> > Pankaj Sanghi
>> >>> hi everybody,
> Example
> are
> jface
> can
> use
> this
> Which
>> >>> regards
>> >>> Pankaj Sanghi
>> >>> at
>> >> ..java:76)
>> >>> at
>> >> ava:108)
>> >>> at
>> >> java:194)
>> >>> at
>> >> ..java:134)
>> >>> at
>> >> ..java:118)
>> >>> at
>> >>> at
>> >> 5)
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >> java:307)
>> >>> at
>> >>> at
>> >>> at
>> >> 9)
>> >>> at
>> >> alog.java:67)
>> >>> at
>> >>> at
>> >>> at
>> >> Handler.java:83)
>> >>> at
>> >>> at
>> >> va:62)
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >> java:307)
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >> r.java:228)
>> >>> at
>> >>> at
>> >>> at
>> >> ger.java:845)
>> >>> at
>> >>> at
>> >> :608)
>> >>> at
>> >>> at
>> >>> at
>> >> er.java:150)
>> >>> at
>> >> andler.java:104)
>> >>> at
>> >> Handler.java:84)
>> >>> at
>> >>> at
>> >> va:62)
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >> java:307)
>> >>> at
>> >>> at
Re: Error [message #163431 is a reply to message #163394] Mon, 10 January 2005 11:04 Go to previous messageGo to next message
You have a resource leak outside of GEF. Look at the original post. There
are several stack traces showing Images failing to be created.
Re: Error [message #163564 is a reply to message #163431] Tue, 11 January 2005 09:45 Go to previous messageGo to next message
hi all,
What is resource leak and what can be the reason for this. Is it something
related to memory shortage. How can I deal with it.
My plgin is a extension of GEF Logic example with the same drag and drop
facility with some new components. Every time I drag and drop a component,
i paint the component on the canvas and loads its image. So if there are
lot many components on the canvas, there are many Image objects in the
memory. Can this be the reason for failure in creation of images at
certain point of time.
If it is related to memory problem, can it be solved by disposing off the
image object after the component is painted on the canvas. Please help me
resolve this issue.
thanks and regards
Pankaj Sanghi
Re: Error [message #163597 is a reply to message #163564] Tue, 11 January 2005 10:54 Go to previous message
See the SWT articles on resource management.
If you load an Image for each paint, and don't dispose it, this is bad. If
you do dispose it, it's just inefficient code. You might use a resource
cache if you have performance problems.
> resolve this issue.
> thanks and regards
> Pankaj Sanghi
There
Previous Topic:GEF book
Next Topic:jre 1.5
Current Time: Sat Sep 06 12:38:41 EDT 2025
Powered by FUDForum. Page generated in 0.04978 seconds
