Home » Modeling » Epsilon » EVL anf GMF mindmap example
EVL anf GMF mindmap example [message #16337] Wed, 29 April 2009 05:11 Go to next message
Hello!
I'm trying to use EVL validations in the GMF mindmap example with no
success.
I followed all the steps from
http://epsilonlabs.wiki.sourceforge.net/EVL-GMF+Integration.
mindmap.evl looks like this:
context Topic {
constraint ErrorTest {
check : false
message : 'ERROR!'
and plugin.xml:
<?eclipse version="3.4"?>
<plugin>
<extension
point="org.eclipse.epsilon.evl.emf.validation">
<constraintsBinding
constraints="validation/mindmap.evl"
namespaceURI="mindmap">
</constraintsBinding>
</extension>
<extension
point="org.eclipse.ui.ide.markerResolution">
<markerResolutionGenerator
class=" org.eclipse.epsilon.evl.emf.validation.EvlMarkerResolutionGe nerator "
markerType="org.eclipse.gmf.examples.mindmap.diagram.diagnostic ">
</markerResolutionGenerator>
markerType="org.eclipse.emf.ecore.diagnostic">
</extension>
</plugin>
I would gladly appreciate any help.
Re: EVL anf GMF mindmap example [message #16378 is a reply to message #16337] Wed, 29 April 2009 06:27 Go to previous messageGo to next message
Hi Yuri,
The namespaceURI in the constraintBinding of your plugin.xml should be
"http://www.example.org/mindmap" (you can find this in the root EPackage
of mindmap.ecore) instead of "mindmap".
Dimitris
Yuri G wrote:
> Hello!
> success.
> context Topic {
> check : false
> message : 'ERROR!'
> and plugin.xml:
> <plugin>
> <extension
> <constraintsBinding
> </extension>
> <extension
> </extension>
> </plugin>
Re: EVL anf GMF mindmap example [SOLVED] [message #16841 is a reply to message #16378] Wed, 29 April 2009 07:32 Go to previous message
Hello, Dimitris.
Thanks you very much, now it works!
Re: EVL anf GMF mindmap example [message #567262 is a reply to message #16337] Wed, 29 April 2009 06:27 Go to previous message
Hi Yuri,
Dimitris
Yuri G wrote:
> Hello!
> success.
> context Topic {
> check : false
> message : 'ERROR!'
> and plugin.xml:
> <plugin>
> <extension
> <constraintsBinding
> </extension>
> <extension
> </extension>
> </plugin>
Re: EVL anf GMF mindmap example [SOLVED] [message #567295 is a reply to message #16378] Wed, 29 April 2009 07:32 Go to previous message
Hello, Dimitris.
Previous Topic:EWL - Calling a wizard from a wizard
Next Topic:epsilon 0.8.5 generation problem
Current Time: Wed Oct 29 00:46:01 EDT 2025
Powered by FUDForum. Page generated in 0.03862 seconds
