Home » Modeling » GMF (Graphical Modeling Framework) » Change default file name in the "Save as image dialog"
Change default file name in the "Save as image dialog" [message #163239] Thu, 29 November 2007 06:29 Go to next message
Originally posted by: andreas.behnke1.gmx.de
I want to change the behavior of the command "Save as Image File" in the
context menu of my diagram in this way: Give the default file name based
on a feature of my diagrams model element. I can not find the extension
point of this context menu, where can I find it? Is this extension part
of the generated code?
Thanks in advance,
Andreas
Re: Change default file name in the "Save as image dialog" [message #163328 is a reply to message #163239] Thu, 29 November 2007 11:53 Go to previous messageGo to next message
Andreas,
The CopyToImageDialog class constructor takes a default filename, but
this class is internal. You can request to make it public if you want.
The CopyToImageAction constructs the dialog. You could remove the
default CopyToImageAction contribution and add your own subclass. You
would accomplish this with the Contribution Item Service.
- Cherie
Andreas Behnke wrote:
> Hello,
> Thanks in advance,
> Andreas
Re: Change default file name in the "Save as image dialog" [message #163336 is a reply to message #163328] Thu, 29 November 2007 12:47 Go to previous messageGo to next message
Hi Cherie,
I can only find the extension point
" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ".
Is this the correct extension?
> Andreas,
> - Cherie
>> Hello,
>> the context menu of my diagram in this way: Give the default file name
>> based
>> extension point of this context menu, where can I find it? Is this
>> extension part
>> Thanks in advance,
>> Andreas
Re: Change default file name in the "Save as image dialog" [message #163469 is a reply to message #163336] Fri, 30 November 2007 08:51 Go to previous messageGo to next message
Andreas,
Yes. You can look at some of the examples code to see how it is used.
- Cherie
> Hi Cherie,
>> Andreas,
>> want. The CopyToImageAction constructs the dialog. You could
>> remove the default CopyToImageAction contribution and add your own
>> subclass. You would accomplish this with the Contribution Item Service.
>> - Cherie
>>> Hello,
>>> name based
>>> extension part
>>> Thanks in advance,
>>> Andreas
Re: Change default file name in the "Save as image dialog" [message #163591 is a reply to message #163469] Sat, 01 December 2007 16:47 Go to previous messageGo to next message
Hi Cherie,
I could not find any example code which could help for my problem. I
have only one extension point
in my plugin.xml which makes a popup contribution for a special diagram
element. You wrote I should remove the default "CopyToImageAction"
contribution. The following questions arise when trying to do this:
Where can I find the correct ID of this contribution?
What is the path to this contribution?
Are the default contributions documented in the GMF reference documentation?
Is it possible to start without any default contributions?
Please give me a hint for a good example or documentation.
Andreas
The generated extension point:
<extension
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<?gmfgen generated="false"?>
<contributionItemProvider
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContribu tionItemProvider "
checkPluginLoaded="false">
<Priority name="Low"/>
<popupContribution
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider ">
<popupStructuredContributionCriteria
objectClass=" com.behnke.ebpm.businessusecase.edit.parts.BusinessUseCaseRe latedScenariosEditPart "/>
<popupAction path="/editGroup" id="deleteFromModelAction"/>
<popupPredefinedItem id="deleteFromDiagramAction"
remove="true"/>
</popupContribution>
</contributionItemProvider>
</extension>
Cherie Revells schrieb:
> Andreas,
> - Cherie
>> Hi Cherie,
>>> Andreas,
>>> - Cherie
>>>> Hello,
>>>> name based
>>>> extension part
>>>> Thanks in advance,
>>>> Andreas
Re: Change default file name in the "Save as image dialog" [message #163732 is a reply to message #163591] Mon, 03 December 2007 09:42 Go to previous messageGo to next message
Andreas,
If you search for references of CopyToImageAction you will find it
contributed by DiagramUIRenderContributionItemProvider with the id
"CopyToImageAction".
In the org.eclipse.gmf.runtime.diagram.ui.render plugin's plugin.xml
file you will see where it is contributed.
> documentation?
Not that I am aware of.
No, but it has been requested before:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=111221
The Contribution Item Service schema provides documentation on removing
predefined items. See "popupPredefinedItem". I am almost certain you
will find examples of this in some of the generated examples, but I
could be wrong.
Regardless of all this, you are still going to have the problem that the
CopyToImageDialog class is internal.
In my opinion, if you are doing any significant customizations of the
GMF Runtime that are not covered by the examples, it is easiest to learn
by looking at the GMF code itself.
- Cherie
> Hi Cherie,
> documentation?
> Andreas
> <extension
> <popupContribution
> remove="true"/>
> </extension>
>> Andreas,
>> - Cherie
>>> Hi Cherie,
>>>> Andreas,
>>>> but this class is internal. You can request to make it public if
>>>> you want. The CopyToImageAction constructs the dialog. You could
>>>> Service.
>>>> - Cherie
>>>>> Hello,
>>>>> in the context menu of my diagram in this way: Give the default
>>>>> file name based
>>>>> extension part
>>>>> Thanks in advance,
>>>>> Andreas
Re: Change default file name in the "Save as image dialog" [message #164032 is a reply to message #163732] Tue, 04 December 2007 05:12 Go to previous message
Hi Cherie,
I will take your advice. At the moment I only managed to add a new
action to the popup menu with the org.eclipse.ui.popupmenus extension
point. Any contributions to
were without any effect, don't know what I am missing. I will report
back if I have a working solution.
Andreas
Previous Topic:Link cross the nodes
Next Topic:Programatically using a Label
Current Time: Sun Jul 27 01:52:04 EDT 2025
Powered by FUDForum. Page generated in 0.28133 seconds
