Home » Modeling » GMF (Graphical Modeling Framework) » Gradient Facet
Gradient Facet [message #163312] Thu, 29 November 2007 10:15 Go to next message
Originally posted by: martinschmidt.83.web.de
I
Re: Gradient Facet [message #163344 is a reply to message #163312] Thu, 29 November 2007 13:19 Go to previous messageGo to next message
I believe that if you define a GradientFacet with a Rectangle and that
you set its "fill" value to true, this should fill the rectangle with a
gradient style. You have probably to define two colors.
Martin Schmidt a écrit :
> I´m able to add a "Gradient Facet" to a Node in .gmfgraph, but this don´t
> affects the generated code (as far as i seen). Does anybody know what is
> that "Gradient Facet" for?
Re: Gradient Facet [message #163382 is a reply to message #163344] Fri, 30 November 2007 03:07 Go to previous messageGo to next message
That
Re: Gradient Facet [message #163449 is a reply to message #163382] Fri, 30 November 2007 08:21 Go to previous message
Hello Martin,
Looks like "not implemented yet".
Alex Shatalin
Previous Topic:Exception when draw a figure
Next Topic:Best Practice for setting property in Custom Property Section?
Current Time: Sun Aug 31 21:29:45 EDT 2025
Powered by FUDForum. Page generated in 0.04762 seconds
