Home » Eclipse Projects » Sirius » Sirius and Xtext synchronization
Sirius and Xtext synchronization [message #1599245] Tue, 03 February 2015 08:38 Go to next message
I have some issues with the xtext synchronization and i am wondering if there is an example project that uses custom refresh and saving policy like suggested in the eclipsecon 2014 presentation http://www.slideshare.net/cbrun/xtext-sirius.
I found this project: https://github.com/ObeoNetwork/Xtext-Sirius-integration but it seems focussed on the embedded editor.
My main problem is opening the Xtexteditor and select the node of the just created EObject in the sirius diagram. Problem is that the code below will not find the node. (NodeModelUtils seems not updated) To "update" nodemodelutilse the resource is saved (resource.save(null)). But when some object is deleted some object that is still in use and save the resource, unexpected behavior can happen.
Thats why i am looking for the best way to do this. I am not sure if sirius is synchronizing correctly with xtext.
public EObject openTextEditor(EObject any) {
if (any != null && any.eResource() instanceof XtextResource
&& any.eResource().getURI() != null) {
String fileURI = any.eResource().getURI().toPlatformString(true);
IFile workspaceFile = ResourcesPlugin.getWorkspace().getRoot()
.getFile(new Path(fileURI));
if (workspaceFile != null) {
IWorkbenchPage page = PlatformUI.getWorkbench()
.getActiveWorkbenchWindow().getActivePage();
try {
IEditorPart openEditor = IDE.openEditor(page,
workspaceFile,
"org.eclipse.xtext.example.fowlerdsl.Statemachine",
true);
if (openEditor instanceof AbstractTextEditor) {
ICompositeNode node = NodeModelUtils
.findActualNodeFor(any);
if (node != null) {
int offset = node.getOffset();
int length = node.getTotalEndOffset() - offset;
((AbstractTextEditor) openEditor).selectAndReveal(
offset, length);
System.out
.println("StatemachineServices.openTextEditor()");
// editorInput.
} catch (PartInitException e) {
// Put your exception handler here if you wish to.
System.out.println(any);
return any;
btw i have installed "Sirius integration with XText"
But i havent done the following: " Instantiate an XtextResourceSet
Configure the ResourceSet with the project. Change the saving policy " which is on the slide of earlier mentioned presentation
Re: Sirius and Xtext synchronization [message #1622169 is a reply to message #1599245] Wed, 18 February 2015 05:01 Go to previous messageGo to next message
Hi Koen,
You have to save the Sirius session to impact the file you will open in
your Xtext editor.
> String fileURI =
> try {
> workspaceFile,
> true);
> if (node != null) {
> offset;
> offset, length);
> System.out
> // editorInput.
> return any;
If you have installed "Sirius integration withg XText", the
org.eclipse.sirius.common.xtext will provide a XTextResourceSetFactory
which will enable the live scope in the load options and will configure
the resource set (set the platform uri map, the classpath uri context,
the classpath uri resolver). It will also automatically change the
saving policy when an XtextResource is present in the resource set. The
XTextSavingPolicy currently add
SaveOptions.newBuilder().noValidation().getOptions.toOptionsMap() to the
save options.
Maxime - Obeo
Need professional services for Sirius?
Re: Sirius and Xtext synchronization [message #1622388 is a reply to message #1622169] Wed, 18 February 2015 08:09 Go to previous messageGo to next message
Thanks for your answer, Reading your comment i assume sirius should update nodemodelutils if the xtext part is included
I have "Sirius integration with XText" installed.
" org.eclipse.sirius.common.xtext" is set as required Plug-in.
the xtextresourcesetFactory and the xtextsavingpolicy are being used.
The user creates a new eobject with sirius and session.save will be called at the end (the eobject is visible in the xtextedior)
The following user action will use the nodeutils but NodeModelUtils.findNodesForFeature(eObject, feature) returns null
Is there something i missed?
(findNodesForFeature returns null because NodeModelUtils.getnode returns null, the object has no IComposeNode adapter
the object does have the following adapters:
[org.eclipse.xtext.util.OnChangeEvictingCache$CacheAdapter@7942381e, org.eclipse.emf.transaction.impl.TransactionChangeRecorder@75ea824a, org.eclipse.sirius.business.internal.session.danalysis.LocalResourceCollector@771004c0, org.eclipse.sirius.common.tools.api.util.LazyCrossReferencer$InternalCrossReferencer@6a7277c3, org.eclipse.sirius.common.tools.api.util.IDAdapter@183a8b7f, org.eclipse.xtext.util.SimpleAttributeResolver$DiscardingAdapter@7a3117d4, my.project,ItemProvider@c9a0570])
[Updated on: Wed, 18 February 2015 08:16] by Moderator
Re: Sirius and Xtext synchronization [message #1632431 is a reply to message #1622388] Tue, 24 February 2015 04:14 Go to previous message
> I have "Sirius integration with XText" installed. "
I don't know how Xtext works in these aspects, but currently Sirius's
Xtext integration plug-in is strictly about being able to correctly load
and save Xtext models inside Sirius sessions.
If you have both a Sirius session and an Xtext editor opened at the same
time on the same Xtext model, there is no direct synchronization between
them: they both have completely isolated in-memory versions of the Xtext
model, as it was on disk when they loaded it. Modifications in one
context can only be visible to the other if it is saved on disk and
reloaded.
If you make a modification in the Xtext editor, and then save it, the
file will change on disk. Sirius will detect that and update its own
in-memory version with the new content from the disk automatically.
If you make a modification in a Sirius editor, you must first save it.
After that I don't know if the Xtext editor will pick up the updated
content automatically, but from what you say below it seems you make
need some explicit action to do so.
> called at the end (the eobject is visible in the xtextedior) The
Pierre-Charles David - Obeo
Previous Topic:Open a Sirius representation inside a View
Next Topic:Change appearance of model elements
Current Time: Sat Jun 07 02:07:02 EDT 2025
Powered by FUDForum. Page generated in 0.02925 seconds
