Home » Eclipse Projects » Equinox » BundleFileWrapper does not wraps the invocation to getResourceURL
BundleFileWrapper does not wraps the invocation to getResourceURL [message #1626991] Sat, 21 February 2015 03:43 Go to next message
I would like to provide my own BundleFileWrapperFactoryHook in order to wrap the BundleFile. Unfortunately calls to getResourceURL are always delegated to the BundleFile implementation.
Is it intentional that BundleFileWrapper does not wraps the getResourceURL?
The stack is the following:
BundleFileWrapperChain(BundleFile).getResourceURL(String, Module, int) line: 129
ClasspathManager.findResourceImpl(String, BundleFile, int) line: 420
ClasspathManager.findLocalResources(String) line: 397
EquinoxClassLoader(ModuleClassLoader).findLocalResources(String) line: 320
BundleLoader.findLocalResources(String) line: 797
BundleLoader.findResources(String) line: 658
EquinoxClassLoader(ModuleClassLoader).getResources(String) line: 230
I can see that the wrapped in BundleFileWrapperChain is the one provided by me but when getResourceURL is invoked the implementation provided by BundleFile is returned.
Equinox version is Luna.
Thanks and Regards,
Violeta
[Updated on: Sat, 21 February 2015 03:54] by Moderator
Re: BundleFileWrapper does not wraps the invocation to getResourceURL [message #1631151 is a reply to message #1626991] Mon, 23 February 2015 11:16 Go to previous messageGo to next message
This is intentional because the BundleFile super class creates the framework specific protocol 'bundleresource' URLs and the builtin internal handler org.eclipse.osgi.storage.url.bundleresource.Handler object to wrap the entry that is found by delegating to the getEntry method.
As long as your wrapper can provide a BundleEntry for the path then the behavior of the BundleFile.getResourceURL method should work. Can you describe why you need to override the behavior of this method?
Re: BundleFileWrapper does not wraps the invocation to getResourceURL [message #1631295 is a reply to message #1631151] Mon, 23 February 2015 13:06 Go to previous messageGo to next message
It is a common use case that web components (servlets etc.) ask classloader for a resource and then create File object from the returned URL.
We have the following Equinox extension in Virgo [1] which was working with Equinox versions previous to Luna.
Can you suggest how we can achieve the same with Luna?
Violeta
[1] http://git.eclipse.org/c/virgo/org.eclipse.virgo.kernel.git/tree/org.eclipse.virgo.kernel.equinox.extensions/src/main/java/org/eclipse/virgo/kernel/equinox/extensions/hooks/ExtendedBundleFileWrapperFactoryHook.java
Re: BundleFileWrapper does not wraps the invocation to getResourceURL [message #1631367 is a reply to message #1631295] Mon, 23 February 2015 14:03 Go to previous messageGo to next message
I don't have a good suggestion. Perhaps this usecase has been overlooked. Please open a bug to track. We could add the method to the wrapper as a possible solution.
Re: BundleFileWrapper does not wraps the invocation to getResourceURL [message #1631513 is a reply to message #1631367] Mon, 23 February 2015 15:51 Go to previous message
Here it is https://bugs.eclipse.org/bugs/show_bug.cgi?id=460637
Violeta
Previous Topic:Could not acquire the framework manipulator service
Next Topic:WebStart Java 7 update 71 72
Current Time: Sun Jul 27 09:43:48 EDT 2025
Powered by FUDForum. Page generated in 0.03724 seconds
