Home » Language IDEs » Java Development Tools (JDT) » Dividing eclipse projects into subprojects
Dividing eclipse projects into subprojects [message #163096] Mon, 07 June 2004 17:57 Go to next message
Originally posted by: abhijit_dhariaDELETETHIS.stercomm.com
I am working on a code-base consisting of more than 6000 classes/files.
To start working with this, I usually create a prject by pointing eclipse
to the root directory of this class structure and let eclipse figure
everything out. At this stage I cannot supply filename filters.
So problem is that I presume, eclipse has to go through all the files in
that directory. Since these files are being accessed over the network, it
takes a really long time ( more than 30 minutes) to create or reopen a
project.
Also, after the project is created, I see frequent 'pauses' when I try to do
things like change perspectives or debug!
Needless to say, outOfMemory exceptions are also pretty common.
Does anybody have any ideas? Has anybody else faced similar problems? What
are the workarounds for this?
--Abhi
Re: Dividing eclipse projects into subprojects [message #163144 is a reply to message #163096] Tue, 08 June 2004 08:15 Go to previous messageGo to next message
> project.
Rethink your layout - use CVS + local filesystem.
Use command line to start Eclipse.
Give at least '-Xmx' to the Java VM.
Sam Mesh - http://openrules.com
Re: Dividing eclipse projects into subprojects [message #163686 is a reply to message #163096] Wed, 09 June 2004 21:54 Go to previous messageGo to next message
> project.
how about using cvs?
a.
Re: Dividing eclipse projects into subprojects [message #163703 is a reply to message #163096] Thu, 10 June 2004 10:33 Go to previous message
> project.
> --Abhi
Start eclipse from command line with
"eclipse.exe -vmargs -Xmx256m" , it will help you solve the
OutOfMemoryExceptions.
Sunay
Previous Topic:confusion over jdt Markers - how much due to compiler, how much to AST syntax analysis?
Next Topic:Problem with radio actionsets
Current Time: Thu Sep 18 01:50:58 EDT 2025
Powered by FUDForum. Page generated in 0.03947 seconds
