Home » Archived » BIRT » 'org.eclipse.birt.report.data.oda.jdbc_2.0.0' is not found!
'org.eclipse.birt.report.data.oda.jdbc_2.0.0' is not found! [message #162863] Fri, 19 May 2006 06:42
Originally posted by: hjm.holos.pt
I'm trying to build birt rcp application from the cvs code.
In the NewReportWizard.java i use this code
OdaDataSourceHandle dsHandle = DesignElementFactory.getInstance(
HandleAdapterFactory.getInstance( )
.getReportDesignHandleAdapter( )
.getModuleHandle( )
.getDataSources( )
.getElementHandle( )
.getModuleHandle( ) )
.newOdaDataSource("Datasource-jdbc","org.eclipse.birt.report.data.oda.jdbc ");
When i use the Launch an Eclipse application from the
org.eclipse.birt.report.designer.ui.rcp plugin.xml file i get this error
message:
Unhandled event loop exception
Reason:
The extension with ID 'org.eclipse.birt.report.data.oda.jdbc_2.0.0' is not
found!
How can i correct the error?
Hugo Morganho
Previous Topic:print report
Next Topic:Any success passing Datetime as parameter balue to frameset viewer?
Current Time: Sat Aug 16 17:36:59 EDT 2025
Powered by FUDForum. Page generated in 0.03344 seconds
