Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon] Exeed (EXtended Emf EDitor)
[Epsilon] Exeed (EXtended Emf EDitor) [message #375953] Fri, 02 February 2007 10:32 Go to next message
In the context of the Epsilon component we have implemented Exeed, an
extension to the built-in reflective EMF editor that supports
customizing labels and icons in the model editor tree by adding
annotations to the respective ECore metamodel. A preliminary guide to
the tool is available at http://www.eclipse.org/gmt/epsilon/doc/Exeed.pdf
Dimitrios
Re: [Epsilon] Exeed (EXtended Emf EDitor) [message #1627963 is a reply to message #375953] Sat, 21 February 2015 16:52 Go to previous message
Hi Dimitris,
I want to work with Exeed and for the first attempt, I try the example exeedoo which works fine. I read the manual that you reference to it (exeed.pdf). It says to use new icons, they must be placed in the path: <eclipse-installation>/plugins/org.epsilon.eclipse.dt.exeed/icons/
However, when I copy my own icons in this path it couldn't work well. Only it works for the old icons which were there before.
My icons are 16x16 .gif extension.
would you please guide me how to solve that?
Leila
Previous Topic:GMF Tooling: GWT generation issue
Next Topic:This forum has been archived.
Current Time: Fri Jul 18 23:54:58 EDT 2025
Powered by FUDForum. Page generated in 0.05366 seconds
