Home » Modeling » EMF » CDI annotations - customize generated code
CDI annotations - customize generated code [message #1626999] Sat, 21 February 2015 03:48 Go to next message
I have searched this forum, many times, and googled - trying to find how to add annotations.
I have seen various posts saying how easy it is to customize the generated code using annotations - but cannot find any information on how to add annotations - as in, in the generated java.
For those of use who want to annotate our classes - say, for use in CDI, with scopes, qualifiers etc, how can we do this?
[Updated on: Sat, 21 February 2015 05:21] by Moderator
Re: CDI annotations - customize generated code [message #1627956 is a reply to message #1626999] Sat, 21 February 2015 16:50 Go to previous messageGo to next message
Anton,
Depending on which editor you use the process for creating annotations
is can be different. I assume you're referring to EAnnotations on your
Ecore model, right? In the Sample Ecore Editor, you can create an
EAnnotation from the context menu and details for that annotation also
via the context menu.
On 21.02.2015 09:48, Anton Hughes wrote:
> Hi
> to add annotations.
> adding annotations.
> Thanks
Re: CDI annotations - customize generated code [message #1628470 is a reply to message #1627956] Sat, 21 February 2015 23:48 Go to previous messageGo to next message
Thanks Ed
So, it is possible to add annotations to classes and methods?
For example
@MyCustomAnnotation
MyClass {
   @MyMethodAnnotation
   public void myMethod(){
Can you confirm it is possible to do this using EAnnotations?
Re: CDI annotations - customize generated code [message #1632069 is a reply to message #1628470] Mon, 23 February 2015 23:27 Go to previous message
Anton,
No, EAnnotations don't directly generate Java annotations. One would
need to specialize the templates for that. I'm not sure if there are
include points for annotations and I don't have a full development
environment available until next week to answer in more detail.
On 22.02.2015 05:48, Anton Hughes wrote:
> Thanks Ed
> For example
> @MyCustomAnnotation
> MyClass {
> @MyMethodAnnotation
Previous Topic:[EMF Transaction] Transaction.getChangeDescription()
Next Topic:[EMF] Generation Gap EcoreGenerator
Current Time: Fri Jul 25 23:58:44 EDT 2025
Powered by FUDForum. Page generated in 0.07119 seconds
