Home » Eclipse Projects » GEF » When getCreateCommand() will be called?
When getCreateCommand() will be called? [message #162680] Thu, 23 December 2004 08:59 Go to next message
Originally posted by: zhlmmc.hotmail.com
If I write getCreateCommand() like this:
protected Command getCreateCommand(CreateRequest request) {
/*CreateCommand command = new CreateCommand();
Rectangle constraint = (Rectangle) getConstraintFor(request);
HelloModel model = (HelloModel) request.getNewObject();
model.setConstraint(constraint);
command.setContentsModel(getHost().getModel());
command.setHelloModel(model);
return command;*/
return null;
GEF will stop me dragging the component from palette to the
EditPartViewer,has this method been called before my operation?Otherwise
how could system know that this method returns null and should reject this
operation?
Thank you :)
Re: When getCreateCommand() will be called? [message #162688 is a reply to message #162680] Thu, 23 December 2004 12:21 Go to previous messageGo to next message
If you're doing click-and-drop, it will. But not with drag-and-drop (which
is native). Set a breakpoint in that method to see when it's being called.
"zhlmmc" <zhlmmc@hotmail.com> wrote in message
news:cqej09$rid$1@www.eclipse.org...
> return command;*/
> return null;
> operation?
> Thank you :)
Re: When getCreateCommand() will be called? [message #162711 is a reply to message #162680] Thu, 23 December 2004 16:40 Go to previous message
Do you have a TemplateTransferDropTarget on your graphical viewer? Put a
breakpoint in its handleDragOver or whatever the method is called.
> return command;*/
> return null;
> operation?
> Thank you :)
Previous Topic:Non printable layer and Outline Overview
Next Topic:Problem with picture using plugin
Current Time: Wed Jul 30 12:12:01 EDT 2025
Powered by FUDForum. Page generated in 0.03723 seconds
