Home » Eclipse Projects » GEF » How to handle a delete command that needs to prompt user?
How to handle a delete command that needs to prompt user? [message #162411] |
Tue, 21 December 2004 16:19  |
Originally posted by: simon.ibm.com
I have a generic delete action. In its run method, loops over all the
currently selected edit parts, and asked each one for a delete command. That
is, I call getCommand() on each edit part, which in turn ends up calling
getCommand() on my ComponentEditPolicy.
All is working well except for one scenario. Some edit parts can be
"referenced" by other edit parts. So we want to prompt the user to confirm
they are willing to delete these other edit parts also. How could that be
done? Because some of these edit parts (that can be referenced by other edit
parts) can be contributed by other plugins, I do not know about them in
advance in my delete action to check for them and prompt the user.
There are not "connection" line between these edit parts. The only
indication of the reference is each edit part that is dependent on another
edit part contains the name of that edit part in its property. Since these
edit parts may not be visible on the screen at the time of the delete, the
user is "surprised" later on when scrolling in the editor and noticing other
edit parts are gone.
Anyone else have this problem/situation? If so, what did you do?
Simon :-)
Re: How to handle a delete command that needs to prompt user? [message #162541 is a reply to message #162411] |
Wed, 22 December 2004 08:47   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
create a new CancellableDeleteAction
let that open dialog to ask about what to and not to delete. once
proper list generated then issue the real delete command.
that is how i would do it.
> Thanks
> Simon :-)
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: How to handle a delete command that needs to prompt user? [message #162556 is a reply to message #162541] |
Wed, 22 December 2004 10:35   |
"CL [dnoyeb] Gilbert" <Lamont_Gilbert@rigidsoftware.com> wrote in message
news:cqbtst$oe3$1@www.eclipse.org...
The command could open a dialog and there a several cases where this makes
sense. It's good practice to allow the user to avoid aa prompt by pressing
ESC. So they choices would be, delete just selected, delete dependents, or
cancel the action (it isn't necessary to display a cancel button, just hook
dialog's ESC).
To handle the first two, I don't think you need to create a second command,
you could just modify the command which displayed the dialog. But that
leaves the cancel case. I'm not sure how to abort a command. You'd have to
extend the API. Maybe you could run some pre-execute method which return
boolean.
That
confirm
be
edit
another
these
the
other
> > Thanks
> > Simon :-)
> Respectfully,
> CL Gilbert
> and a robber."
Re: How to handle a delete command that needs to prompt user? [message #162596 is a reply to message #162541] |
Wed, 22 December 2004 13:30   |
Did you mean CancellableDeleteCommand instead of CancellableDeleteAction? If
so, do you have a sample you could post here?
Simon :-)
That
confirm
be
edit
another
these
the
other
> > Thanks
> > Simon :-)
> Respectfully,
> CL Gilbert
> and a robber."
Re: How to handle a delete command that needs to prompt user? [message #162602 is a reply to message #162556] |
Wed, 22 December 2004 13:32   |
For whatever reason, I was under the impression that opening a dialog from
within a command was not considered "proper style". I will try this out.
Simon :-)
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cqc47u$fsp$1@www.eclipse.org...
or
hook
> dialog's ESC).
command,
to
> boolean.
command.
> That
calling
> confirm
> be
other
> edit
in
> another
> these
> the
> other
> > > Thanks
> > > Simon :-)
> > Respectfully,
> > CL Gilbert
> > and a robber."
Re: How to handle a delete command that needs to prompt user? [message #162610 is a reply to message #162602] |
Wed, 22 December 2004 14:40   |
I don't see it as a real problem. I know Text team records offsets and
length in their commands, which are purely UI data. You will of course want
to null out any fields which hold onto dialogs, etc., once execute has
completed.
"Simon" <simon@ibm.com> wrote in message
news:cqcekj$iif$1@www.eclipse.org...
> Thanks
> Simon :-)
message
makes
pressing
> or
> hook
> > dialog's ESC).
> command,
have
> to
return
> > boolean.
the
> command.
> > That
> calling
> > confirm
that
> > be
> other
> > edit
> in
> > another
> > these
delete,
> > the
noticing
> > other
> > > > Thanks
> > > > Simon :-)
> > > Respectfully,
> > > CL Gilbert
into
> > > and a robber."
Re: How to handle a delete command that needs to prompt user? [message #162634 is a reply to message #162596] |
Wed, 22 December 2004 18:31  |
> Thanks
IIRC, the action can generate the command if the proper conditions are
met. That is why i suggested a new action. cancelling a command is not
really GEF style i dont think, but if you dont start the command till
you know exactly what to delete and what not to, then their is no need
to cancel it.
> Simon :-)
> That
> confirm
> be
> edit
> another
> these
> the
> other
>>>Thanks
>>>Simon :-)
>>Respectfully,
>>CL Gilbert
>>and a robber."
Respectfully,
CL Gilbert
and a robber."
Current Time: Wed Jul 30 07:07:03 EDT 2025
Powered by FUDForum. Page generated in 0.06413 seconds
