Home » Modeling » EMF » How to remove a transaction from TransactionalEditingDomain
How to remove a transaction from TransactionalEditingDomain [message #1625289] Fri, 20 February 2015 04:22 Go to next message
Hello All,
I am developing a feature with the help of EMF wherein after the feature is invoked i should be able to undo and redo.
However now within this feature I have to use another TransactionalEditingDomain & RecordingCommand inside
Display.getDefault().asyncExec(new Runnable() {
.......code goes in here.....
So now when I perform Undo, first time nothing happens and then when I perform the second Undo, then the actual feature is undone. This happens for the obvious reason that I have used another RecordingCommand.
Now I would like to remove the last RecordingCommand from the command stack so that with a single undo, the feature is undone.
So could anybody please help me out in removing the last recording command.
Thanks & Regards,
Rahul
[Updated on: Fri, 20 February 2015 04:23] by Moderator
Re: How to remove a transaction from TransactionalEditingDomain [message #1625616 is a reply to message #1625289] Fri, 20 February 2015 09:11 Go to previous message
Hi, Rahul,
See some replies in-line, below.
HTH,
Christian
On 2015-02-20 09:22:25 +0000, Rahul Dev Mishra said:
> Hello All,
EMF is generally very good at undo and redo, yes.
Why do you have to use a second editing domain? What does this command
do? Why does it have to be run asynchronously? Asynchronously
executing commands on the command stack or operation history is almost
never a good idea. Commands should be invoked in direct response to a
user request (button press, menu action, keystroke).
It sounds like this additional command that you are executing should be
a trigger command (provided by a transaction pre-commit listener) since
you seem to be using transactions. And wouldn't it already be running
on the UI thread because it is in response to a user action?
> perform the
Why does the first undo not change anything? If that command didn't
change anything and if it therefore doesn't undo any changes, then it
shouldn't be on the command stack or operation history in the first
place.
Right, because that recording command isn't properly composed with the
changes that came before it into a single undoable unit.
No, I think you need to take a step back and find out how to avoid
putting that command on the stack in the first place.
> Thanks & Regards,
> Rahul
Previous Topic:EMF: Pupulating ordered list of "scatterd" items
Next Topic:Eclipse not starting
Current Time: Fri Jul 25 20:32:32 EDT 2025
Powered by FUDForum. Page generated in 0.02825 seconds
