Home » Eclipse Projects » GEF » About creating an Image
About creating an Image [message #162376] Tue, 21 December 2004 11:14 Go to next message
Originally posted by: zhlmmc.hotmail.com
Why I have to create an Image in this way:
InputStream stream = MyPlugin.class.getResourceAsStream("shapes.gif");
Image image = new Image(null, stream);
try {
stream.close();
} catch (IOException ioe) {
If I write like this:
Image image = new Image(null,"shapes.gif");
will throw an exception?
thanks
Re: About creating an Image [message #162387 is a reply to message #162376] Tue, 21 December 2004 11:42 Go to previous messageGo to next message
Please post the exception and Image. Probably you should ask on SWT
newsgroup.
"zhlmmc" <zhlmmc@hotmail.com> wrote in message
news:cq9i5l$bnf$1@www.eclipse.org...
> try {
> stream.close();
> thanks
Re: About creating an Image [message #162456 is a reply to message #162387] Tue, 21 December 2004 18:54 Go to previous messageGo to next message
i/o exception FileNotFound
I put the .class and the .shapes in the same directory and my jface
application window can show the gif correctly,but my gef plugin throw
the exception.
> newsgroup.
>> try {
>> stream.close();
>> thanks
Re: About creating an Image [message #162478 is a reply to message #162456] Tue, 21 December 2004 21:03 Go to previous messageGo to next message
Of course you should get that exception. When you omit the path of the
file name, it is assumed that your file is located in the directory your
jvm started up rather than the directory which contains both your
specified class and that image file.
> the exception.
>> newsgroup.
>>> try {
>>> stream.close();
>>> thanks
Re: About creating an Image [message #162494 is a reply to message #162478] Tue, 21 December 2004 22:28 Go to previous messageGo to next message
I see...but could you tell me why my jface application can find the file?
I think I'm not clear about the mechanism of the plugin loader in Eclipse.
>> the exception.
>>> newsgroup.
>>>> try {
>>>> stream.close();
>>>> thanks
Re: About creating an Image [message #162502 is a reply to message #162494] Tue, 21 December 2004 23:56 Go to previous messageGo to next message
I think it is because of your eclipse launcher set the working directory
for your jface application. However, calling new Image(null, filename)
is equivalent to calling new Image(null, new FileInputStream(
filename)). You might want to print the URLs constructed by
new File(".").toURL() in both applications to see the difference.
> thanks :)
>> your jvm started up rather than the directory which contains both your
>>> the exception.
>>>> newsgroup.
>>>>> try {
>>>>> stream.close();
>>>>> thanks
Re: About creating an Image [message #162519 is a reply to message #162502] Wed, 22 December 2004 00:18 Go to previous message
file:/D:/Program
Files/eclipse-SDK-3.0.1-win32/eclipse/workspace/HelloWorld/. /
file:/D:/Program Files/eclipse-SDK-3.0.1-win32/eclipse/./
It's clear now :)
Thank you!
>> thanks :)
>>>> the exception.
>>>>> newsgroup.
>>>>>> try {
>>>>>> stream.close();
>>>>>> thanks
Previous Topic:How to add figures programmatically
Next Topic:What is GEF
Current Time: Fri Jul 18 07:32:38 EDT 2025
Powered by FUDForum. Page generated in 0.06353 seconds
