Home » Eclipse Projects » GEF » How to add figures programmatically
How to add figures programmatically [message #162448] Tue, 21 December 2004 18:38 Go to next message
I'd like to programmatically add figures to the diagram using the
commands that GEF uses.
How can I add an AbstractGraphicalEditPart to the diagram without using
the palette to manually add an edit part. I'd like to use the same
commands (extending org.eclipse.gef.commands.Command) that would be
returned from the various methods of XYLayoutEditPolicy.
I know how to create a command, but don't know what to do with it in my
action.
I'd be very happy if someone could help me put editparts into the
diagram from within an action.
Thanks in advance for any hint,
Christian
Re: How to add figures programmatically [message #162463 is a reply to message #162448] Tue, 21 December 2004 19:10 Go to previous messageGo to next message
> I'd like to programmatically add figures to the diagram using the commands
> that GEF uses.
One nice thing about Eclipse is that you can follow the call path into the
GEF source if you need to. Following the call path for
EditPart.getCommand(...) you end up in AbstractTool.executeCurrentCommand()
which points you to the CommandStack which is retrieved from the EditDomain.
So at the end of the day you just need to:
commandStack.execute(yourCommand);
Rob Grzywinski
Re: How to add figures programmatically [message #162470 is a reply to message #162463] Tue, 21 December 2004 20:29 Go to previous messageGo to next message
Thanks Rob. That seems to work, however, I don't know whether this is a
good solution.
But thanks anyway.
Christian
Re: How to add figures programmatically [message #162486 is a reply to message #162463] Tue, 21 December 2004 21:19 Go to previous message
Why not just create the command programmatically because there is no
tools invoked by user activity? Maybe it is better to bother less objects.
>>that GEF uses.
> Rob Grzywinski
Previous Topic:PropertyView driven from selections in Editor
Next Topic:About creating an Image
Current Time: Wed Jul 30 08:54:59 EDT 2025
Powered by FUDForum. Page generated in 0.08927 seconds
