About creating an Image [message #162376] |
Tue, 21 December 2004 11:14  |
Originally posted by: zhlmmc.hotmail.com
Why I have to create an Image in this way:
InputStream stream = MyPlugin.class.getResourceAsStream("shapes.gif");
Image image = new Image(null, stream);
try {
stream.close();
} catch (IOException ioe) {
If I write like this:
Image image = new Image(null,"shapes.gif");
will throw an exception?
thanks
Re: About creating an Image [message #162519 is a reply to message #162502] |
Wed, 22 December 2004 00:18  |
file:/D:/Program
Files/eclipse-SDK-3.0.1-win32/eclipse/workspace/HelloWorld/. /
file:/D:/Program Files/eclipse-SDK-3.0.1-win32/eclipse/./
It's clear now :)
Thank you!
Cloudor Pu wrote:
> I think it is because of your eclipse launcher set the working directory
> for your jface application. However, calling new Image(null, filename)
> is equivalent to calling new Image(null, new FileInputStream(
> filename)). You might want to print the URLs constructed by
> new File(".").toURL() in both applications to see the difference.
> zhlmmc wrote:
>> I see...but could you tell me why my jface application can find the file?
>> I think I'm not clear about the mechanism of the plugin loader in Eclipse.
>> thanks :)
>> Cloudor Pu wrote:
>>> Of course you should get that exception. When you omit the path of the
>>> file name, it is assumed that your file is located in the directory
>>> your jvm started up rather than the directory which contains both your
>>> specified class and that image file.
>>> zhlmmc wrote:
>>>> i/o exception FileNotFound
>>>> I put the .class and the .shapes in the same directory and my jface
>>>> application window can show the gif correctly,but my gef plugin throw
>>>> the exception.
>>>> Randy Hudson wrote:
>>>>> Please post the exception and Image. Probably you should ask on SWT
>>>>> newsgroup.
>>>>> "zhlmmc" <zhlmmc@hotmail.com> wrote in message
>>>>> news:cq9i5l$bnf$1@www.eclipse.org...
>>>>>> try {
>>>>>> stream.close();
>>>>>> thanks
FUDForum. Page generated in 0.03794 seconds
