Home » Newcomers » Newcomers » Problems Moving Project from NetBeans to Eclipse(Project runs with NetBeans on Mac but not with Eclipse, at least 2 problems)
Problems Moving Project from NetBeans to Eclipse [message #1620283] Mon, 16 February 2015 23:57 Go to next message
I am new to both Eclipse and the Mac, have a MacBook Pro with OS X 10.10 Yosemite. Had been developing a project using Java and PostgreSQL on a Dell Win 7 with NetBeans. Due to several reasons I decided to bite the bullet and move to a Mac 1) to make some changes and additions to the present project and 2) to develop a related project under Eclipse. (Other folks who might further develop these project are working with Eclipse; thus, I felt I should work in only one SDK - Eclipse to make things simpler for myself and others in the future.)
I installed NetBeans 8.0.2 SDK on the Mac. The identical program developed under NetBeans works both on the Win 7 and on the Mac.
However, when I moved the code for the present project into Eclipse (Luna 4.4.1) there are several errors, indicated in my bracketed comments below.
Error 1:
package ui;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
//import java.awt.print.PrinterException; // this I can take care of
import java.sql.*;
import javax.swing.JFrame;
import javax.swing.JOptionPane;
import org.postgresql.util.PSQLException;
[above: the above import cannot be resolved]
import java.nio.file.Files;
import java.io.*;
import java.util.ArrayList;
[line 23: ] public class Globals extends javax.swing.JFrame implements ActionListener {
[above: "The serializable class Globals does not declare a static final serialVersionUID field of type long" - deprecated??]
public static ArrayList<String> searchTerms = new ArrayList<>();
public static String outputToWhere = "";
static JFrame frame;
public static Connection con = null;
[The second error is the following, on below: "Class is a raw type. References to generic type Class<T> should be parameterized." - this is something completely new to me; I never saw this in the old NetObjects.]
[line 164:] public static Class loadDriver(String driverName) {
try {
return (Class.forName(driverName));
} catch (ClassNotFoundException e) {
[The following is the third error, which I have been trying to solve, but do not know where to find the CLASSPATH on the Mac.
"Class is a raw type. References to generic type Class<T> should be parameterized." same as above. -- Note: this works with NetObjects on the Mac. I get a "unresolved compilation problem" on line 190.]
[line 190:] public static void sign_on() {
Class driverClass = loadDriver("org.postgresql.Driver");
if (driverClass == null) {
return;
System.out.println("Connection successful");
con = connectURL("jdbc:postgresql://localhost/pg1",
"postgres", "ginkat8a");
[How do I set the CLASSPATH in Eclipse on the Mac? Where is it?]
Help will be greatly appreciated.
Re: Problems Moving Project from NetBeans to Eclipse [message #1620737 is a reply to message #1620283] Tue, 17 February 2015 06:46 Go to previous messageGo to next message
> comments below. Error 1:
> package ui;
> import java.sql.*;
> import java.io.*;
> ActionListener {
> try {
> but do not know where to find the CLASSPATH on the Mac. "Class is a raw
> return;
Welcome to the Eclipse community.
"The serializable class..."
"Class is a raw type..."
You can turn these warnings/errors off. Go to Window -> Preferences ->
Java -> Compiler -> Errors/Warnings, and find the setting. You can
adjust these, turning what are added protections off, to be only
warnings or to be errors as you wish.
These are really Java questions and not so much Eclipse questions. You
should take the time to check out the reason behind each of these.
Google is your friend or you can ask at javaranch.com.
Best of luck.
Re: Problems Moving Project from NetBeans to Eclipse [message #1623192 is a reply to message #1620737] Wed, 18 February 2015 20:00 Go to previous messageGo to next message
Thanks.
I got rid of the raw stuff.
Now I'm off to solve what I think is the CLASSPATH problem. I can't find where to put it on this new machine.
Will try javaranch.com.
Again, many thanks.
Re: Problems Moving Project from NetBeans to Eclipse [message #1623234 is a reply to message #1620737] Wed, 18 February 2015 20:41 Go to previous messageGo to next message
Thanks.
Again, many thanks.
Re: Problems Moving Project from NetBeans to Eclipse [message #1624782 is a reply to message #1623234] Thu, 19 February 2015 20:22 Go to previous messageGo to next message
On 02/18/2015 06:41 PM, David Rogers wrote:
> Thanks.
> Again, many thanks.
It's not a CLASSPATH issue, it's a Java 5 versus Java pre-5 issue. You
don't use
Class
anymore, but instead
Class< something here >
depending on what you're doing with it. You might use
Class< ? >
depending and assuming what you're doing won't blow chunks when you're
holding something you didn't expect.
You see, it's really a Java question. I hope you got help.
Cheers
Re: Problems Moving Project from NetBeans to Eclipse [message #1746236 is a reply to message #1620283] Tue, 25 October 2016 16:01 Go to previous message
absolved.
Previous Topic:Java Virtual Memory Usage at Eclipse startup
Next Topic:Installing Lucene
Current Time: Sun Jul 27 08:13:31 EDT 2025
Powered by FUDForum. Page generated in 0.07890 seconds
